[mapserver-dev] Reminder of upcoming 8.0 release plan dates
Worth Lutz wal3 at mindspring.com
Fri Apr 23 07:45:48 PDT 2021
Hi All,
I'm having a time getting MapServer built on RHEL8 due to recent PostGIS
and GDAL packages in the pgdg repository using different versions of
Proj. The ones that are consistent all use Proj 8. I can find a PostGIS
that uses Proj7 but the GDAL package that meets the requirements uses Proj8.
My question is does this upcoming release 7.6.3 allow MapServer to be
built with Proj 8?  I believe that would solve my dilemma.
Regards,
*Worth Lutz*
On 4/14/2021 3:41 PM, Jeff McKenna wrote:
> Hi all,
> Please get your branch-7-6 changes done this month, as on April 30th
> we'll do a 7.6.3 release, as the feedback for this idea seems quite
> positive from users ('release early, release often'). Thanks again,
> -jeff
> On 2021-04-07 11:08 a.m., Jeff McKenna wrote:
>> Hi devs,
>> With the recent proposed changes coming down the pipe for 8.0, I feel
>> that we must again push back the 8.0 release dates much more, to
>> something more realistic & to give time for feedback and testing for
>> these major upcoming changes. August/September is our usual big
>> release deadline each year, so here are the proposed date changes for
>> 8.0 :
>>    Feature freeze: Fri. August 6, 2021
>>    8.0-beta1: Fri. August 13, 2021
>>    8.0-beta2: Fri. August 20, 2021
>>    8.0-rc1: Fri. August 27, 2021
>>    8.0 (final): Fri. September 3, 2021
>> I've updated the release plan to point to the latest draft RFCs etc.
>> https://github.com/mapserver/mapserver/wiki/MapServer-8.0-Release-Plan
>> (please edit if I missed anything)
>> Also, likely it would be good for the community to have another 7.6
>> bugfix release, so 7.6.3, as there are a couple of changes in the
>> pipeline that would be useful for users, while they wait for the big
>> 8.0:
>> https://github.com/mapserver/mapserver/compare/rel-7-6-2...branch-7-6
>> Therefore I propose that we release 7.6.3 at the end of this month
>> (April 30th).
>> Please share your thoughts here.
>> Thanks,
>> -jeff
>> On 2021-02-26 1:29 p.m., Jeff McKenna wrote:
>>> Thanks Steve, I was about to ask today about the dates.  Here are
>>> the new proposed dates:
>>>    Feature freeze: Fri. April 9, 2021
>>>    8.0-beta1: Fri. April 16, 2021
>>>    8.0-beta2: Fri. April 23, 2021
>>>    8.0-rc1: Fri. April 30, 2021
>>>    8.0 (final): Fri. May 7, 2021
>>> -jeff
>>> On 2021-02-26 1:12 p.m., Steve Lime wrote:
>>>> I'm going to need to push those dates back (suggest 1 month) for
>>>> the couple of pull requests I have in progress. --Steve
>>>> On Wed, Feb 3, 2021 at 11:42 AM Jeff McKenna
>>>> <jmckenna at gatewaygeomatics.com
>>>> <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>>>>     Hi devs,
>>>>     Reminder of the upcoming 8.0 release plan dates (as mentioned on
>>>> <https://github.com/mapserver/mapserver/wiki/MapServer-8.0-Release-Plan>
>>>>         Feature freeze: Fri. March 5, 2021
>>>>         8.0-beta1: Fri. March 12, 2021
>>>>         8.0-beta2: Fri. March 19, 2021
>>>>         8.0-rc1: Fri. March 26, 2021
>>>>         8.0 (final): Fri. April 2, 2021
>>>>     Please share your thoughts if anyone has any planned big
>>>> changes that
>>>>     may need to delay the above plan a bit, which is fine of
>>>> course.  We
>>>>     can
>>>>     adjust the dates accordingly.
>>>>     (some may prefer to see the list of tickets tagged for this 8.0
>>>>     milestone instead:
>>>>     https://github.com/MapServer/MapServer/milestone/54
>>>> <https://github.com/MapServer/MapServer/milestone/54> )
>>>>     Thanks all,
>>>>     -jeff
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210423/31a1d7a9/attachment.html>
