[mapserver-dev] Reminder of upcoming 8.0 release plan dates
Even Rouault even.rouault at spatialys.com
Fri Apr 23 07:58:20 PDT 2021
Le 23/04/2021 à 16:45, Worth Lutz a écrit :
> Hi All,
> I'm having a time getting MapServer built on RHEL8 due to recent
> PostGIS and GDAL packages in the pgdg repository using different
> versions of Proj. The ones that are consistent all use Proj 8. I can
> find a PostGIS that uses Proj7 but the GDAL package that meets the
> requirements uses Proj8.
> My question is does this upcoming release 7.6.3 allow MapServer to be
> built with Proj 8?  I believe that would solve my dilemma.
yes, in the mean time you need to apply
https://github.com/MapServer/MapServer/commit/3c6f3f0963a03e4968dfdb886eb2d27ae12abfd6
on top of 7.6.2
> Regards,
> *Worth Lutz*
> On 4/14/2021 3:41 PM, Jeff McKenna wrote:
>> Hi all,
>> Please get your branch-7-6 changes done this month, as on April 30th
>> we'll do a 7.6.3 release, as the feedback for this idea seems quite
>> positive from users ('release early, release often').  Thanks again,
>> -jeff
>> On 2021-04-07 11:08 a.m., Jeff McKenna wrote:
>>> Hi devs,
>>> With the recent proposed changes coming down the pipe for 8.0, I
>>> feel that we must again push back the 8.0 release dates much more,
>>> to something more realistic & to give time for feedback and testing
>>> for these major upcoming changes. August/September is our usual big
>>> release deadline each year, so here are the proposed date changes
>>> for 8.0 :
>>>    Feature freeze: Fri. August 6, 2021
>>>    8.0-beta1: Fri. August 13, 2021
>>>    8.0-beta2: Fri. August 20, 2021
>>>    8.0-rc1: Fri. August 27, 2021
>>>    8.0 (final): Fri. September 3, 2021
>>> I've updated the release plan to point to the latest draft RFCs etc.
>>> https://github.com/mapserver/mapserver/wiki/MapServer-8.0-Release-Plan
>>> (please edit if I missed anything)
>>> Also, likely it would be good for the community to have another 7.6
>>> bugfix release, so 7.6.3, as there are a couple of changes in the
>>> pipeline that would be useful for users, while they wait for the big
>>> 8.0:
>>> https://github.com/mapserver/mapserver/compare/rel-7-6-2...branch-7-6
>>> Therefore I propose that we release 7.6.3 at the end of this month
>>> (April 30th).
>>> Please share your thoughts here.
>>> Thanks,
>>> -jeff
>>> On 2021-02-26 1:29 p.m., Jeff McKenna wrote:
>>>> Thanks Steve, I was about to ask today about the dates.  Here are
>>>> the new proposed dates:
>>>>    Feature freeze: Fri. April 9, 2021
>>>>    8.0-beta1: Fri. April 16, 2021
>>>>    8.0-beta2: Fri. April 23, 2021
>>>>    8.0-rc1: Fri. April 30, 2021
>>>>    8.0 (final): Fri. May 7, 2021
>>>> -jeff
>>>> On 2021-02-26 1:12 p.m., Steve Lime wrote:
>>>>> I'm going to need to push those dates back (suggest 1 month) for
>>>>> the couple of pull requests I have in progress. --Steve
>>>>> On Wed, Feb 3, 2021 at 11:42 AM Jeff McKenna
>>>>> <jmckenna at gatewaygeomatics.com
>>>>> <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>>>>>     Hi devs,
>>>>>     Reminder of the upcoming 8.0 release plan dates (as mentioned on
>>>>> <https://github.com/mapserver/mapserver/wiki/MapServer-8.0-Release-Plan>
>>>>>         Feature freeze: Fri. March 5, 2021
>>>>>         8.0-beta1: Fri. March 12, 2021
>>>>>         8.0-beta2: Fri. March 19, 2021
>>>>>         8.0-rc1: Fri. March 26, 2021
>>>>>         8.0 (final): Fri. April 2, 2021
>>>>>     Please share your thoughts if anyone has any planned big
>>>>> changes that
>>>>>     may need to delay the above plan a bit, which is fine of
>>>>> course.  We
>>>>>     can
>>>>>     adjust the dates accordingly.
>>>>>     (some may prefer to see the list of tickets tagged for this 8.0
>>>>>     milestone instead:
>>>>> https://github.com/MapServer/MapServer/milestone/54
>>>>> <https://github.com/MapServer/MapServer/milestone/54> )
>>>>>     Thanks all,
>>>>>     -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210423/410c09a5/attachment-0001.html>
