[MapServer-dev] Basemaps update
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jun 22 07:43:06 PDT 2023
Hi Yves,
Good point, we can at least agree on standard branch naming.  I like
your way of "mapserver-version", so "mapserver-8", "mapserver-7.6" etc.
(I was referring to the fact that we likely shouldn't rename existing
branches, such as the existing "branch-6-2")
-jeff
On 2023-06-22 4:13 a.m., Yves Jacolin wrote:
> Thank for the update!
> why do you think this is too late to get a standard way for naming the
> branches? What will be the standard way?
> Thanks,
> Y.
> Le mer. 21 juin 2023 à 20:18, Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>> a
> écrit :
>     Hi Yves!
>     I just updated the README (and added a backback GitHub action) to the
>     repository.  Now if we want to backport a pull request we can add the
>     label 'backport mapserver-8' to the pull request, and the magic will
>     happen when we merge it.
>     I updated the README text as follows (please update it if it needs more
>     clarifications or if I made mistakes):
>     Please perform all pull requests into the main branch, and inside the
>     pull request mention which branch to backport the changes to; one of
>     the
>     repository managers will then apply the corresponding label, to
>     magically backport to that branch.
>           - use branch `main' for all for all pull requests
>           - other branches to backport to include:
>               - mapserver-7.6
>               - branch-6-2
>     (I really wish we had used a standard way for naming the branches, but,
>     too late now ha)
>     PS. thanks for your many 8.x updates!
>     -jeff
>     Jeff McKenna
>     GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>     co-founder of FOSS4G
>     http://gatewaygeo.com/ <http://gatewaygeo.com/>
>     On 2023-06-20 10:15 a.m., Yves Jacolin wrote:
>      > Hello Developpers community, :)
>      > Following last update in MapServer 7.6 et 8.0 I created two
>     branches in
>      > basemaps project to get basemaps working with such version of
>     MapServer.
>      > Finally, the fix could be backported to main branch so we don't
>     need two
>      > new branches but ...
>      > # The README tells;
>      >  > use the branch corresponding to your mapserver version, e.g.
>      >   * branch-6-2 for mapserver versions 6.2.X
>      >   * master for development/current mapserver versions
>      > so I don't know what is the best strategy. Creating a branch for
>     each
>      > MapServer version could be a lot of maintenance work.
>      > What do you think? One branch most compatible with most of MapServer
>      > Release or one branch by release?
>      > Y.
>      > This is Yves Jacolin's card. Their email is
>     yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>.
>      > Their phone number is +33 6 18 75 42 21. Their phone number is
>     +33 4 58
>      > 48 20 43. Their phone number is +41 21 619 10 43.
>      > <https://hihello.me/p/c7a536d1-5177-4817-8924-ebb067e58d4f
>     <https://hihello.me/p/c7a536d1-5177-4817-8924-ebb067e58d4f>>
Jeff McKenna
More information about the MapServer-dev mailing list
