[MapServer-dev] Basemaps update
Yves Jacolin yves.jacolin at camptocamp.com
Thu Jun 22 07:44:56 PDT 2023
ok let's stay as is and use the "new" name.
Thanks,
Y.
Le jeu. 22 juin 2023 à 16:42, Jeff McKenna <jmckenna at gatewaygeomatics.com>
a écrit :
> Hi Yves,
> Good point, we can at least agree on standard branch naming.  I like
> your way of "mapserver-version", so "mapserver-8", "mapserver-7.6" etc.
> (I was referring to the fact that we likely shouldn't rename existing
> branches, such as the existing "branch-6-2")
> -jeff
> On 2023-06-22 4:13 a.m., Yves Jacolin wrote:
> > Thank for the update!
> > why do you think this is too late to get a standard way for naming the
> > branches? What will be the standard way?
> > Thanks,
> > Y.
> > Le mer. 21 juin 2023 à 20:18, Jeff McKenna
> > <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> a
> > écrit :
> >     Hi Yves!
> >     I just updated the README (and added a backback GitHub action) to the
> >     repository.  Now if we want to backport a pull request we can add the
> >     label 'backport mapserver-8' to the pull request, and the magic will
> >     happen when we merge it.
> >     I updated the README text as follows (please update it if it needs
> more
> >     clarifications or if I made mistakes):
> >     Please perform all pull requests into the main branch, and inside the
> >     pull request mention which branch to backport the changes to; one of
> >     the
> >     repository managers will then apply the corresponding label, to
> >     magically backport to that branch.
> >           - use branch `main' for all for all pull requests
> >           - other branches to backport to include:
> >               - mapserver-7.6
> >               - branch-6-2
> >     (I really wish we had used a standard way for naming the branches,
> but,
> >     too late now ha)
> >     PS. thanks for your many 8.x updates!
> >     -jeff
> >     Jeff McKenna
> >     GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> >     co-founder of FOSS4G
> >     http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >     On 2023-06-20 10:15 a.m., Yves Jacolin wrote:
> >      > Hello Developpers community, :)
> >      > Following last update in MapServer 7.6 et 8.0 I created two
> >     branches in
> >      > basemaps project to get basemaps working with such version of
> >     MapServer.
> >      > Finally, the fix could be backported to main branch so we don't
> >     need two
> >      > new branches but ...
> >      > # The README tells;
> >      >  > use the branch corresponding to your mapserver version, e.g.
> >      >   * branch-6-2 for mapserver versions 6.2.X
> >      >   * master for development/current mapserver versions
> >      > so I don't know what is the best strategy. Creating a branch for
> >     each
> >      > MapServer version could be a lot of maintenance work.
> >      > What do you think? One branch most compatible with most of
> MapServer
> >      > Release or one branch by release?
> >      > Y.
> >      > This is Yves Jacolin's card. Their email is
> >     yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>.
> >      > Their phone number is +33 6 18 75 42 21. Their phone number is
> >     +33 4 58
> >      > 48 20 43. Their phone number is +41 21 619 10 43.
> >      > <https://hihello.me/p/c7a536d1-5177-4817-8924-ebb067e58d4f
> >     <https://hihello.me/p/c7a536d1-5177-4817-8924-ebb067e58d4f>>
> Jeff McKenna
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
[image: This is Yves Jacolin's card. Their email is
yves.jacolin at camptocamp.com. Their phone number is +33 6 18 75 42 21. Their
phone number is +33 4 58 48 20 43. Their phone number is +41 21 619 10 43.]
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230622/77b1873b/attachment-0001.htm>
More information about the MapServer-dev mailing list
