Another 3.3 update...
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Nov 12 14:59:10 EST 1999
This one fixes a few unpublicized features such as url calls to change
map file parameters. Seperator is '_' instead of a ':' which should help
with using javascript (for Kieran). Also changes all structure member names
to match names published as part of the map file ducumentation. This
should help users when using mapscript. Keywords will be the same everywhere
(map file, perl, urls) although some restrictions on case will be required.
- http://mapserver.gis.umn.edu/dist/ms_3.3.tar.gz
Again, examples are running at http://arachnid.dnr.state.mn.us/ms_test/index.html .
Hope to have a mapscript example running yet this afternoon.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
