Labels for timezones layer
Stephen Lime
steve.lime at dnr.state.mn.us
Tue Nov 23 12:18:11 EST 1999
Can't be done, at least not without some custom coding. You might be able to
create an interesting effect by stacking 3 maps on top of each other where:
- top map is narrow and displays only the timezone labels (centered)
- main map is defined as normal
- bottom map is narrow and displays only the timezone labels (centered)
Extents would need to be constant between the 3 maps but that shouldn't be
that hard to do. You'll need some javascript to do this unless you're developing
a custom client. This is a sneaky way to add all sorts of effects to interfaces.
Just an idea...
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Marc JACQUIN - GEOSYS Inc - Minneapolis <mjacquin at geosys-inc.com> 11/23/99 10:27AM >>>
Hi everyone,
I am using the timezones layer (ESRI) and I would like to display the
number of the zone. The problem is to display them at the top and the
bottom of the map at any zoom factor, in other words not at the center
of the polygon. I would like to avoid generating a specific point layer
dynamically. Any idea ?
Thanks,
Marc
