diff for configure.in
Thomas T. Thai
tom at minnesota.com
Thu Jun 1 17:03:01 EDT 2000
attached is the diff for configure.in to properly include runtime library
paths for dynamic libraries. i've tested this out on NetBSD and should
work for other *BSD ELF systems.
--- configure.in Thu Jun 1 15:58:24 2000
+++ configure.in.mod Thu Jun 1 14:31:54 2000
@@ -70,7 +70,7 @@
test -f $GD_DIR/libgd.a && GD_LIBDIR="$GD_DIR"
if test -n "$GD_INCLUDE" -a -n "$GD_LIBDIR" ; then
GD_INC=-I$GD_INCLUDE
- GD_LIB="-L$GD_LIBDIR -lgd"
+ GD_LIB="-Wl,-R$GD_LIBDIR -L$GD_LIBDIR -lgd"
else
AC_MSG_ERROR("Could not find gd.h or libgd.a in $GD_DIR. Make sure gd is compiled before calling configure.")
fi
@@ -84,7 +84,7 @@
else
dnl
- dnl --width-gd was not given... look in system libs, and if not found
+ dnl --with-gd was not given... look in system libs, and if not found
dnl then use the local copy of gd 1.2
dnl
AC_CHECK_LIB(gd, gdImageGif, GD_DEF=-DUSE_GD_1_2,,)
@@ -100,7 +100,7 @@
MAKE_GD_CLEAN=gd_clean
AC_EXPAND_PATH(gd-1.2, GD_DIR)
GD_INC=-I$GD_DIR
- GD_LIB="-L$GD_DIR -lgd"
+ GD_LIB="-Wl,-R$GD_DIR -L$GD_DIR -lgd"
test -f $GD_DIR/Makefile.in && GD_MAKEFILE="$GD_DIR/Makefile"
AC_MSG_RESULT([ using GD ($GD_DEF) from $GD_DIR.])
fi
@@ -146,7 +146,7 @@
if test -n "$TIFF_INCLUDE" -a -n "$TIFF_LIBDIR" ; then
TIFF_INC=-I$TIFF_INCLUDE
- TIFF_LIB="-L$TIFF_LIBDIR -ltiff"
+ TIFF_LIB="-Wl,-R$TIFF_LIBDIR -L$TIFF_LIBDIR -ltiff -lz"
else
AC_MSG_ERROR("Could not find tiffio.h or libtiff.a in $TIFF_DIR.")
fi
@@ -198,7 +198,7 @@
test -f $JPEG_DIR/libjpeg.a && JPEG_LIBDIR="$JPEG_DIR"
if test -n "$JPEG_INCLUDE" -a -n "$JPEG_LIBDIR" ; then
JPEG_INC=-I$JPEG_INCLUDE
- JPEG_LIB="-L$JPEG_LIBDIR -ljpeg"
+ JPEG_LIB="-Wl,-R$JPEG_LIBDIR -L$JPEG_LIBDIR -ljpeg"
else
AC_MSG_ERROR("Could not find jpeglib.h.h or libjpeg.a in $JPEG_DIR.")
fi
@@ -277,7 +277,7 @@
test -f $TTF_DIR/libttf.so && TTF_LIBDIR="$TTF_DIR"
if test -n "$TTF_INCLUDE" -a -n "$TTF_LIBDIR" ; then
TTF_INC=-I$TTF_INCLUDE
- TTF_LIB="-L$TTF_LIBDIR -lttf"
+ TTF_LIB="-Wl,-R$TTF_LIBDIR -L$TTF_LIBDIR -lttf"
else
AC_MSG_ERROR("Could not find freetype.h or libttf.so in $TTF_DIR.")
fi
@@ -304,7 +304,7 @@
dnl We need to link with the GDFT directory as well
dnl
AC_EXPAND_PATH(gdft, GDFT_DIR)
- TTF_LIB="-L$GDFT_DIR -lgdft $TTF_LIB"
+ TTF_LIB="-Wl,-R$GDFT_DIR -L$GDFT_DIR -lgdft $TTF_LIB"
TTF_INC="-I$GDFT_DIR $TTF_INC"
MAKE_GDFT="gdft"
MAKE_GDFT_CLEAN="gdft_clean"
@@ -353,7 +353,7 @@
test -f $PROJ_DIR/libproj.a && PROJ_LIBDIR="$PROJ_DIR"
if test -n "$PROJ_INCLUDE" -a -n "$PROJ_LIBDIR" ; then
PROJ_INC=-I$PROJ_INCLUDE
- PROJ_LIB="-L$PROJ_LIBDIR -lproj"
+ PROJ_LIB="-Wl,-R$PROJ_LIBDIR -L$PROJ_LIBDIR -lproj"
else
AC_MSG_ERROR("Could not find projects.h or libproj.a in $PROJ_DIR.")
fi
@@ -381,7 +381,7 @@
MS_DIR="`pwd`"
MS_INC="-I$MS_DIR"
-MS_LIB="-L$MS_DIR -lmap"
+MS_LIB="-Wl,-R$MS_DIR -L$MS_DIR -lmap"
AC_SUBST(MS_INC, $MS_INC)
AC_SUBST(MS_LIB, $MS_LIB)
