diff for configure.in
Daniel Morissette
danmo at videotron.ca
Fri Jun 2 19:00:48 EDT 2000
"Thomas T. Thai" wrote:
> attached is the diff for configure.in to properly include runtime library
> paths for dynamic libraries. i've tested this out on NetBSD and should
> work for other *BSD ELF systems.
The diffs have been included in the master copy of the configure script
on the CVS server, but the runtime library path have been made optional
to avoid causing side-effects on other platforms where they're not
required. *BSD users (and others with problems with runtime libpath)
should use the new "--enable-runpath" configure option to enable the
"-Wl,-R" flags that will make the *BSD linker happy.
This should hopefully be part of one of the next nightly builds on the
web site.
Daniel Morissette danmo at videotron.ca
http://pages.infinit.net/danmo/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
