TIFFIsByteSwapped: solution
Andrew E Long
aelon at sph.umich.edu
Thu Jun 8 10:32:16 EDT 2000
Stephen wins the prize. This was exactly the problem: another version of
libtiff.so lying around.... Thanks!
Andy
On Wed, 7 Jun 2000, Stephen Lime wrote:
> Might there be other versions of libtiff on the system? Perhaps in the
other libs defined in LD_LIBRARY_PATH?
> s.
> <<< Andrew E Long <aelon at sph.umich.edu> 6/ 7 9:49p >>>
> Hi Folks,
> I've got the ms_3.3.010 mapserver & demo running using the latest and
> greatest of the usual software suspects (e.g. libtiff), but am crashing
> ignominously when I get to the LandSat TM Image: if I try to display it,
> all crashes. Checking the error log for my web server, I find
> ld.so.1: mapserv: fatal: relocation error: file mapserv: symbol
> TIFFIsByteSwapped: referenced symbol not found
> TIFFIsByteSwapped is definitely contained in the libtiff
> distribution, and I find it in libtiff.so, which is in
> /usr/local/lib.
> I've added the LD_LIBRARY_PATH variable to Apache (thanks Daniel
> Morissette), which includes /usr/local/lib, i.e.
> SetEnv LD_LIBRARY_PATH /usr/lib:/usr/openwin/lib:/usr/ucblib:/usr/local/lib
> Any bright ideas, hints, or?
> Thanks,
> Andy
