TIFFIsByteSwapped
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Jun 8 10:22:18 EDT 2000
No, still 8-bit or less...
>>> "Brent Fraser" <bfraser at geoanalytic.com> 06/08/00 09:18AM >>>
What's the color depth of your images? As I recall I think
it needs to be 256 colors (paletted image), not 24 -bit
color. Or has that restriction been removed?
Brent Fraser
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, June 07, 2000 8:46 PM
Subject: TIFFIsByteSwapped
> Hi Folks,
> I've got the ms_3.3.010 mapserver & demo running using the latest and
> greatest of the usual software suspects (e.g. libtiff), but am crashing
> ignominously when I get to the LandSat TM Image: if I try to display it,
> all crashes. Checking the error log for my web server, I find
> ld.so.1: mapserv: fatal: relocation error: file mapserv: symbol
> TIFFIsByteSwapped: referenced symbol not found
> TIFFIsByteSwapped is definitely contained in the libtiff
> distribution, and I find it in libtiff.so, which is in
> /usr/local/lib.
> I've added the LD_LIBRARY_PATH variable to Apache (thanks Daniel
> Morissette), which includes /usr/local/lib, i.e.
> SetEnv LD_LIBRARY_PATH
/usr/lib:/usr/openwin/lib:/usr/ucblib:/usr/local/lib
> Any bright ideas, hints, or?
> Thanks,
> Andy
