Mapscript in mod_perl: frequent errors in mapObj->new
imap at chesapeake.net imap at chesapeake.net
Thu Jun 8 03:28:54 EDT 2000
Markus/MapServer List,
On the topic of mod_perl problems...  a similar experience.
A client of mine tried to run under fastCGI, but Steve reports a
memory leak with PIXMAP symbols and we pretty much concluded that
mapObj->new is not reiterate.  That never did work for us.
It would be ideal to instantiate the mapfile/symbols only once
and crank out mapObjects over and over via mod_perl or fastCGI.
Probably all that is needed is some initialization and free()s
to solve the issues.   That request gets deferred to Steve
for the TODO list.
After testing fastCGI, they had some success getting *very* quick
map generations.... but they backed off the idea until there is
some resolution to the mapObj->new and memory leak malfuntions.
I know it was eventually consuming all of the available RAM on
the machine as a bad side effect.  I'll ask Jim to elaborate
on the details on the testing.
along the performance issues, the thing that would make a fastCGI
mod_perl configuration wildly successful is to snap-to quantified
zoom/panning ratios so that you build a decent cache of images.
That has been somewhat tested and for a high volume application,
I think that is the way to go.
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
410-257-3187
Markus Spring wrote:
> Hi list,
> unfortunately there is no further info. In the http_error.log it
> tells only the line, in some very rare cases it mentions an ioctl
> problem (in german, as I use a german SuSE Linux) and then even the
> command line script will hang until I kill the http processes.
> It looks to me as if there is a file close/lock problem with the mapfile
> itself,
> but I do not understand enough C to add some debugging messages.
> Kind regards - markus
