some progress building MapScript on NT
Brent Fraser
bfraser at geoanalytic.com
Tue Jun 13 13:19:47 EDT 2000
Steve (and list subscribers),
I'm using the makefile created by using the
command "perl makefile.pl" (I'm using ActivePerl,
on NT 4.0. I then do an "nmake" at the command
line.
I removed the "-nodefaultlib" from the makefile
(what a hacker), and now it will compile to a DLL
using "nmake". I then did a "nmake install" and it
seemed to work (it copied files into the ActivePerl
directory and updated some other files).
I tried the dump.pl perl script in the mapscript
examples directory, and got the following error:
Error: Parse Exception
When I use perl interactively, and type in the first
line of the dump.pl script "use mapscript;" I get
the same error as above. So likely some perl file
has not been updated properly so it will recognize
the mapscript package.
Any perl experts out there..?
Brent Fraser
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <bfraser at geoanalytic.com>
Sent: Tuesday, June 13, 2000 9:11 AM
Subject: Re: some progress building MapScript on NT
Which makefiles you using and are you using the perl MakeMaker
module to build the perl code? I'm a win32 neophyte so how to install
the dll is a mystery. A note to the list might help cause I think there are
a bunch of people trying to do this same thing.
s.
>>> "Brent Fraser" <bfraser at geoanalytic.com> 06/13/00 09:24AM >>>
Steve,
Well, it looks like we won't have to change the variable names
(maybe). I edited the Makefile at the line CCFLAGS (approx
line 244) and removed -TP and -DPERL_OBJECT.
Things compiled alot cleaner, but I still had some unresolved
symbols at the linking stage. I added perlCAPI.lib to the list
of libaries in perlvars, and inserted #include "perlCAPI.h" into
mapscript_wrap.c
It compiles and links in the VC++ GUI. I actually get a DLL !
However, on the command line with nmake, the linking stage
gives unresolved symbols in regex and proj of "HUGE" and
"pctype". I'm not sure if it's worth pursuing since I can use
the GUI to produce the DLL.
Now that I have a mapscript.dll (the same as mapscript.so
in Unix?), what do I do with it (be nice!)? Do I need to place
it in the perl dir tree somewhere?
Thanks,
Brent
GeoAnalytic Inc.
#300 , 700 - 4th Avenue SW Calgary, AB T2P 3J4
Tel: (403)213-2700 Fax: (403)213-2707
www.geoanalytic.com
