Changing map file parameters
bfischer at usgs.gov
Wed Mar 22 11:09:58 EST 2000
Hello mapserv users,
I am trying to change map file parameters on the fly. I understand I have
to use form variables, but there is not much documentation on how to use
them. Here is what I am trying to do. I have a polygon coverage of
watersheds. The user selects a watershed by a mouse click. From this I am
able to acess all the attributes from that polygon. Now I want to use this
polygon's attributes to form a class expression and query expression on the
same polygon shapefile. The output I need is a map with all the polygons
highlighted that got selected in the class expression. Here is the HTML
code I am using, am I doing something wrong? All it returns is the image
from the previous point query. One problem I noticed is the [DOWNSTREAM],
[FROM_DON_], and [TO_DON_] get turned into the values of the polygon's
attributes that got selected from the mouse click.
<form name="query_map" method="GET" action="/cgi-bin/mapserv.exe">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map_layer_0_classitem" value="DOWNSTREAM">
<input type="hidden" name="map_layer_0_class_expression" value
=(([DOWNSTREAM] ge [FROM_DON_]) and [DOWNSTREAM] le [TO_DON_]))">
<input type="hidden" name="map_layer_0_class_color" value="255 255 0">
<imput type="image" name="img" src="../watershed/temp_mapserv/[img]"
border="0">
</form>
Does any onw have any suggestions? Would this also be possible to do with
a URL instead of form variables?
Thanks,
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
