drift and type
Trevor Banister
Banister at BANISTER.COM
Fri Mar 24 15:55:25 EST 2000
Check your html template to make sure that img.x, and img.y exist and
default to the center of your image (1/2 the dimension).
I suspect that img.x and img.y are both too big in your template which is
causing the drift.
Trevor Banister
-----Original Message-----
Sent: Thursday, March 23, 2000 4:38 PM
To: MapServer Users List
Subject: drift and type
HI all-
Two basic questions:
1) I have continental drift going on in the java version of MS at my site.
With every submit the "map" drifts to the lower right, eventually going
off the image area. I realize its California, but ... I have tried
changing the map extent to no effect. Do I really need to crank down
the map extent to acheive the centering I desire or is there another
solution?
2) In unix/linux: When I implement freetype, etc as part of MS, do I need
to make a library path change so that these will function- they don't
now, I get an error if I uncomment them now. Could someone post a
sample so that I can try it out if this something that I need to do.
Thanks in advance,
Mike Hass
