Projection + Index bug?
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Mar 29 15:43:53 EST 2000
Greetings: I found the bug that was causing this problem. It's fixed
in 3.3.010 which should be released shortly. It makes indexes useless
when MapServer is compiled with proj.4 enabled.
s.
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Peter deVoil <devoilp at dpi.qld.gov.au> 03/28/00 04:49PM >>>
I had similar experiences with 3.3.006 when rendering an image (with no
projection) at anything other than full extents. I didn't pursue it much
further than deleting the .qix files. I was using a WinNT/mingw32
platform.
Yours
PdeV.
Trevor Banister wrote:
> I've noticed that if a layer is projected, and there is a .qix file it shows
> up in the legend, but the vectors don't display at all. Renaming the .qix
> file to .qixtest or deleting it fixes the issue, but then the application
> runs slower without the indexing.
> Anyone else run into this issue?
> Trevor Banister
> Banister Consulting
