Fwd: arcview color definition
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at peligroso.gaiaenv.com
Wed Mar 29 17:58:35 EST 2000
Hi Markus,
Not too clear what you are attempting to do, but here is the essense of
extracting RGB values from ODB/AVL storage format, according to our
Avenue-guy. I assume you have ArcView (I wasn't sure from your
message). Script1 essentially creates an ODB with color values in it
and then Script2 extracts them...hope this gets you started.
'Script Number 1:
'Writes colors out to an ODB. Colors are stored in ODB in hexadecimal
format.
theODBFN = "$TEMP\colors.odb".AsFilename
theODB = ODB.Make(theODBFN)
the1stColor = Color.Make
the1stColor.SetRGBList({212, 155, 96})
theODB.Add(the1stColor)
the2ndColor = Color.Make
the2ndColor.SetRGBList({21, 15, 9})
theODB.Add(the2ndColor)
theODB.Commit
'Script Number 2:
'Reads colors in from the ODB created in Script Number 1. Displays the
RGB values (GetRGBList) in a MsgBox.
theODB = ODB.Open(theODBFN)
the1stColor = theODB.Get(0)
the2ndColor = theODB.Get(1)
MsgBox.ListAsString(the1stColor.GetRGBList, "First Color in ODB",
"Color")
MsgBox.ListAsString(the2ndColor.GetRGBList, "Second Color in ODB",
"Color")
Cheers,
Jim
Stephen Lime wrote:
> Subject: arcview color definition
> Date: Wed, 29 Mar 2000 17:19:52 +0200
> From: Markus Spring <rgu at ems.muenchen.de>
> Reply-To: Markus.Spring at mindless.com
> To: mapserver-info at lists.gis.umn.edu
> I am trying to convert ARCVIEW ODB-Format Color definition like
> Red: 0x8a38
> Green: 0xe385
> Blue: 0x3166
> to Mapserver-Mapfile format, but without reasonable results.
> Any help would be appreciated
> regards - markus spring
