ITEMQUERY problem
Jonathan Candy
jonathancandy at hotmail.com
Fri Oct 20 16:03:56 EDT 2000
I recently started using MapServer and am really impressed by the
functionality - an incredible job by Stephen Lime and others. I am using
MapServer Version 3.3.011 under NT with IIS 4.0
I am working through the basics, can display,zoom,pan, have solved most
problems looking the the doc and user mail archives but have run into
trouble with ITEMQUERY. My query returns the correct field value, but not an
image. I have not solved the problem using the doc. and user mail archives
so I hope someone can point out my (simple) error.
I have two files: query3.map and query3.html
I enter:
http://142.232.148.68/scripts/mapserv.exe?map=c:\inetpub\wwwroot\bcit\query3.map&mode=map
and I get my map image correctly
I enter:
http://142.232.148.68/scripts/mapserv.exe?map=c:\inetpub\wwwroot\bcit\query3.map&mode=itemquery&item=code&value=SW5
and I get the Query text result correctly (so the query does work) but no
map images.
Here is the query3.map file (I have made a simplified version for testing)
NAME QUERY3
EXTENT 499767 5454803 499928 5455434
SIZE 200 300
SHAPEPATH "d:\arcwork\bcitdata\"
WEB
IMAGEPATH "c:\inetpub\wwwroot\bcit\images\"
IMAGEURL "/bcit/images/"
END
LAYER
NAME "bcitsw"
DATA sw
STATUS DEFAULT
TYPE POLYGON
CLASSITEM Code
CLASS
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
QUERY
TEMPLATE "c:\inetpub\wwwroot\bcit\query3.html"
END
END
END
Here is the query3.html file (as simple as possible)
<html><body>
Query Result:
Building Name:</b> [CODE]<br><b>Type:</b> [TYPE]<br>
Images should appear below:<p>
<img src="[img]">
<img
src="/scripts/mapserv.exe?map=[map]&item=Code&value=[value]&mode=itemquerymap&mapext=shapes">
</body></html>
So when I enter the command
I get the query result but no images: (My sw.dbf file does have a record
with field code=SW5 and type=JON so the query works)
Query Result: Building Name: SW5
Type: JON
X X
Here is the source of the HTML result file:
<!-- MapServer Version 3.3.011 -PROJ.4 -FreeType -TIFF -EPPL7 -->
<html><body>
Query Result:
Building Name:</b> SW5<br><b>Type:</b> JON<br>
<img src="/bcit/images/QUERY3972060490443.gif">
<img
src="/scripts/mapserv.exe?map=c:\inetpub\wwwroot\bcit\query3.map&item=Code&value=SW5&mode=itemquerymap&mapext=shape
s">
</body></html>
The QUERY3972060490443.gif is not placed in the /bcit/images directory.
However, tThe directory does get a .GIF file when I use the mode=map
command.
All answers really appreciated.
regards,
Jonathan Candy
BCIT GIS Department
e-mail: jcandy at bcit.ca
Tel: 604-432-8378.
www.gis.bcit.ca
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
