Solved: RE: debugging?
    Matt.Wilkie
    Matt.Wilkie at gov.yk.ca
    Fri Oct 20 13:36:44 PDT 2000
> Is there some method to make debugging a little easier?
> I'm trying to build my own .map files now and I'm getting
> errors like "loadString(): Incorrect data type. (105):(3)"
> but I don't know how to find out *which* command in the
> .map file is passing the wrong data type.
I figured it out.
The last set of brackets contain the line# (starting at 0)
	(3) 		# line 3
the previous brackets contain the value mapserv choked on:
	(105)		# the line in the mapfile was: NAME  105d11
So mapserver parsed "NAME 105d11" as an integer when a
string was expected. The solution is to make sure you
quote values when you need them interpreted as characters
instead of numbers.
	NAME	"105d11"
cheers,
-matt
Matt Wilkie * GIS Technician * Yukon Renewable Resources GIS
http://renres.gov.yk.ca/pubs/rrgis/
More information about the MapServer-users
