scale, class & itemquery
Robin.Ellis at dnr.qld.gov.au
Tue Oct 24 20:20:47 EDT 2000
Has anybody experienced difficulties with zooming into an area based on an
ITEMQUERY with mapext=shapes when one of the layers that will form the
returned image has a MAXSCALE set and there are numerous CLASSES defined for
this layer?
I realise this sounds absurd, but my situation is this:
I am able to zoom to a shire based on a shire name selected from a menu.
Along with the queried Shire layer, I can also return a number of other
layers like property boundaries etc. These extra layers are exhibited
normally depending on wehther or not the MAXSCALE poroperty is set. However
I have one layer (showing ecosystem areas) that normally has about 10
classes set for shading purposes and a MAXSCALE set. This layer operates
normally when using the standard zoom and pan functions, however when I try
to zoom to a shire area using ITEMQUERY, this layer causes the operation to
fail. I can get around this in 2 ways, niether of which is desireable.
Firstyly, I can remove my MAXSCALE propetry. That's ok, but this is a large
data set and I don't want it exhibited when viewed from 'too far out'.
Secondly, I can remove the NAME property from all of my CLASSes. This, of
course, leaves with no Legend produced for the classes of this layer!! (I
can actually leave up to 2 NAMEs in my classes, any more and I get trouble).
I'd be keen to hear if anybody else has experience this type of problem, and
even keener to hear about a possible solution.
We're using version 3.3.011 on a UNIX server.
Thanks
Rob
Robin Ellis
Land Resources Officer
Department of Natural Resources
Burnett District
ph: 07 4131 5771
fax: 07 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
