Strange lines when zoomed in
Stephen Lime steve.lime at dnr.state.mn.us
Wed Oct 25 12:20:01 EDT 2000
The *only* way to get that artifact is by drawing line shapefiles as polygon/polyline layers.
There are no polyline shapefiles.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Doyon, Jean-Francois" <Jean-Francois.Doyon at CCRS.NRCan.gc.ca> 10/25/00 10:38AM >>>
Yup, I've seen that just change the type from POLYLINE to LINE and that
problem will go away.
I'm not sure the logic behind that though, since I had the same problem with
rivers doing that, even though
they ARE polylines, I have to set them as LINES to avoid it.
J.F.
> From: 	RAldridge[SMTP:RAldridge at linuxstart.com]
> Sent: 	Wednesday, October 25, 2000 9:43 AM
> To: 	mapserver-users at lists.gis.umn.edu
> Subject: 	Strange lines when zoomed in
> I was wondering if anyone else had this problem, or, better yet, had
> solved this problem.  I have a couple of small shapefiles (roads.shp &
> contours.shp) that aren't drawing properly when zoomed in tight.  The
> contours.shp contains ~1500 polylines and the roads.shp contains 8
> polylines (coverage area is a single section).  Both shapefiles look good
> when zoomed out (e.g. 1:24000), but when I zoom in (to e.g. 1:5000), I get
> stray, straight lines shooting off of endpoints.  The stray lines appear
> to be random in their direction, but always seem to be beginning at
> existing endpoints.
> Any ideas?
> Thanks,
> Robert Aldridge
> Do you do Linux? :)
> Get your FREE @linuxstart.com email address at: http://www.linuxstart.com
