Cached query map
Pericles S. Nacionales
pnaciona at gis.umn.edu
Tue Oct 31 12:48:03 EST 2000
Brian,
You just found another undocumented bit in the mapserver demo. You need to
edit the template file "demo_footer.html" and replace
"queryfile=/usr/local/apache/htdocs/tmp/" from
<img border="2"
src="/cgi-bin/mapserv?map=[map]&queryfile=/usr/local/apache/htdocs/tmp/DEMO[
id].qy[get_layers]&mode=map&size=200+200">
to "queryfile=e:\inetpub\wwwroot\tmp\" or whatever local directory it is you
use to store the mapserver-generated image in.
Good luck!
Perry
----- Original Message -----
To: <mapserver-users at lists>
Sent: Tuesday, October 31, 2000 10:17 AM
Subject: Cached query map
> Sorry to bother everyone again about this - but I still can't get this
part
> of the demo to work.
> Can someone who has followed the demo installation instructions do a query
> and tell me if they get an image showing up as the "cached query" (to the
> right of the one labelled "standard querymap")
> It seems that everything in the demo is working except for this.
> I want to find out if it's my mapserver configuration or a
> directory/file/permissions/path system issue
