PHP, MySQL, and points!
Daniel Morissette
morissette at dmsolutions.on.ca
Tue Oct 31 15:15:25 EST 2000
Frederic Marchand wrote:
> Since i start playing with ms, i've got projection, zoom-in, zoom-out and
> other stuff working on most of maps i've got. But now, i would like to put
> point (like red dot) on the map where my lat,long coord are stored in
> mysql db. I know i can put point using the feature command directly from
> the map file but i would like to know how to create those point directly
> from PHP. I tried to use the object pointObj with the draw functions, but
> in PHP3 module, draw don't exist and in PHP4, where draw is there, there
> is no SHADESET support (as MARKERSET and LINESET).
There are a couple ways to do it:
1- Using pointObj->draw() as you suggested above.
For how to convert your symbol file from 3.3.011 format to the new
format, see:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0010/msg00027.html
2- For best performance in rendering and spatial queries: Convert all
your points to a shapefile... MapServer works very well with
shapefiles.
3- Assuming that you don't display all 110000 points all the time,
but instead run an initial SQL query to pre-select a set of points
to play with based on some client selections, then see:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/0009/msg00059.html
Good Luck!
Daniel Morissette morissette at dmsolutions.on.ca
http://www.dmsolutions.on.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
