ShapeResultObj->shape ?
Daniel Morissette danmo at videotron.ca
Mon Sep 11 18:10:26 EDT 2000
"Doyon, Jean-Francois" wrote:
> Could you post the necessary bit of code to change ? I'd rather keep a
> stable version, since my app should go into production soon.
> but I also want to make sure the code is compatible forward, so I'd like to
> change that "point" to a "line" as it should be :)
In _phpms_build_shape_object(), change the line:
   add_method(return_value, "point", php3_ms_shape_line);
to:
   add_method(return_value, "line", php3_ms_shape_line);
(I'm assuming you're using version 3.3.011... this line is gone
elsewhere in the latest version because we added PHP4 support.)
> And now, I'm having another problem, this time with the getshape() funtion
> It seems to allways return the SAME shape (The first one), regardless of th
> eindex value I give it !
You're really not lucky!  This one has been fixed 1 or 2 days after the
3.3.011 release!  :)
It's the index passed to getshape() that was converted to double
internally... anyways, to fix this in your copy, go in
php3_ms_shapefile_getshape() and look for the line:
    convert_to_double(pIndex);
and change it to:
    convert_to_long(pIndex);
You're definitely good at finding these things... we should get you to
do a QA pass on the module before the next release!  :)
              http://pages.infinit.net/danmo/
  Don't put for tomorrow what you can do today, because if
      you enjoy it today you can do it again tomorrow.
