Demo problem
    Ricardo Wagner Martins
    ricmar at pro.via-rs.com.br
    Wed Sep 13 12:58:06 PDT 2000
Yes, in part. I notice that the address placed in IMAGEPATH must be the same
that I use in Apache directory home , that is, "/home/httpd/html/" so the
unique alteration that I made was:
IMAGEPATH "/home/httpd/html/tmp/"
and works fine. Of course the tmp directory must exist.
Thanks again.
Ricardo
Stephen Lime wrote:
> I'm assuming issues with your temporary directory, does it exist?
> >>> Ricardo Wagner Martins <ricmar at pro.via-rs.com.br> 09/13/00 09:00AM >>>
> I am running Mandrake Linux 7.0.2, Apache 1.3 and mapserv 3.3.010. I've
> been trying to make the demo work. I am having trouble with the display
> of .gif images. They are generated but don t come up in the screen
> "Mapserver Demo Interface". When I try to "View Image" in the browser (
> Netscape 4.7) the answer is "Not found - The request URL
> /tmp/DEMO968850649797.gif was not found on this server."
> I've included the following below:
> * the forms section of demo_init.html file
> * demo.map file
> Many thanks for help
> Ricardo
> ------------------------------------ forms section, demo_init.html
> <input type="hidden" name="map"
> value="/home/httpd/html/ms_demo/demo.map">
> <input type="hidden" name="layer" value="lakes">
> <input type="hidden" name="layer" value="streams">
> <input type="hidden" name="zoomsize" value=2>
> ------------------------------------ demo.map
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> SHADESET "/home/httpd/html/ms_demo/symbols/shade.sym"
> MARKERSET "/home/httpd/html/ms_demo/symbols/marker.sym"
> LINESET "/home/httpd/html/ms_demo/symbols/line.sym"
> EXTENT 388107.634400379 5203120.88405952 500896.339019834
> 5310243.30613897
> UNITS METERS
> SHAPEPATH "/home/httpd/html/ms_demo/data"
> IMAGECOLOR 255 255 255
> # Projection definition, consult the PROJ.4 documentation for parameter
> discussion
> #PROJECTION
> #  "proj=utm"
> #  "ellps=GRS80"
> #  "zone=15"
> #  "north"
> #  "no_defs"
> #END
> # Start of web interface definition
> WEB
>   IMAGEPATH "/usr/local/apache/htdocs/tmp/"
>   IMAGEURL "/tmp/"
>   HEADER demo_header.html
>   TEMPLATE demo.html
>   FOOTER demo_footer.html
>   MINSCALE 1000
>   MAXSCALE 1550000
>   # LOG "demo.log"
> END
> QUERYMAP
>   SIZE 200 200
>   STATUS ON
>   STYLE HILITE
>   COLOR 255 0 0
> END
> # Start of reference map
> REFERENCE
>   IMAGE graphics/reference.gif
>   EXTENT 393234.393701263 5205405.16440722 495769.579718949
> 5307959.02579127
>   SIZE 120 120
>   STATUS ON
>   COLOR -1 -1 -1
>   OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
>   KEYSIZE 18 12
>   LABEL
>     TYPE BITMAP
>     SIZE MEDIUM
>     COLOR 0 0 89
>   END
>   STATUS ON
> END
> # Start of scalebar
> SCALEBAR
>   LABEL
>     COLOR 255 255 255
>     SIZE tiny
>   END
>   STYLE 1
>   SIZE 50 2
>   COLOR 255 255 255
>   UNITS MILES
>   INTERVALS 1
>   TRANSPARENT TRUE
>   STATUS TRUE
> END
> # Start of layer definitions
> LAYER
>   NAME county
>   TYPE POLYGON
>   STATUS DEFAULT
>   DATA ctybdpy2
>   CLASSITEM 'cty_name'
>   CLASS
>     EXPRESSION 'Itasca'
>     OUTLINECOLOR 128 128 128
>     COLOR 225 225 185
>   END
>   CLASS # every other county in the state
>     EXPRESSION /./
>     COLOR 255 255 255
>   END
> END
> LAYER
>   NAME cities
>   TYPE POLYGON
>   DATA mcd90py2
>   STATUS ON
>   CLASSITEM city_name
>   CLASS
>     NAME "Cities & Towns"
>     EXPRESSION /./
>     COLOR 255 225 90
>   END
> END
> LAYER
>   NAME townships
>   TYPE POLYLINE
>   DATA twprgpy3
>   STATUS ON
>   CLASS
>     SYMBOL 1
>     SIZE 2
>     NAME 'Townships'
>     COLOR 181 181 145
>   END
> END
> LAYER
>   NAME lakes
>   TYPE POLYGON
>   STATUS ON
>   DATA lakespy2
>   CLASS
>     NAME 'Lakes & Rivers'
>     COLOR 49 117 185
>   END
>   HEADER "lakespy2_header.html"
>   FOOTER "lakespy2_footer.html"
>   QUERY
>     TEMPLATE "lakespy2.html"
>   END
>   TOLERANCE 3
> END # lakes
> LAYER
>   NAME streams
>   TYPE LINE
>   STATUS ON
>   DATA dlgstln2
>   CLASS
>     NAME "Streams"
>     COLOR 49 117 185
>   END
>   HEADER "dlgstln2_header.html"
>   FOOTER "dlgstln2_footer.html"
>   QUERY
>     TEMPLATE "dlgstln2.html"
>   END
>   TOLERANCE 5
> END # streams
> LAYER
>   NAME roads
>   MAXSCALE 300000
>   STATUS ON
>   DATA ctyrdln3
>   TYPE LINE
>   CLASS
>     COLOR 0 0 0
>   END
> END # county roads
> LAYER
>   NAME roads
>   MAXSCALE 300000
>   STATUS ON
>   DATA ctyrdln3
>   TYPE ANNOTATION
>   LABELITEM "road_name"
>   CLASS
>     COLOR 255 255 255
>     SYMBOL 'county_highway_shield'
>     LABEL
>       MINFEATURESIZE 40
>       MINDISTANCE 150
>       POSITION CC
>       SIZE TINY
>       COLOR 0 0 0
>     END
>   END
> END # county road annotation
> LAYER
>   NAME roads
>   MAXSCALE 600000
>   STATUS ON
>   DATA majrdln3
>   TYPE LINE
>   CLASS
>     NAME "Roads"
>     COLOR 0 0 0
>   END
> END # highways
> LAYER
>   NAME roads
>   MAXSCALE 600000
>   STATUS ON
>   DATA majrdln3
>   TYPE ANNOTATION
>   LABELITEM "road_num"
>   CLASSITEM "road_class"
>   CLASS
>     EXPRESSION "3"
>     COLOR 0 0 0 # dummy color
>     SYMBOL 'state_highway_shield'
>     LABEL
>       MINFEATURESIZE 50
>       MINDISTANCE 150
>       POSITION CC
>       SIZE TINY
>       COLOR 0 0 0
>     END
>   END
>   CLASS
>     EXPRESSION "2"
>     SYMBOL 'us_highway_shield'
>     LABEL
>       MINFEATURESIZE 50
>       MINDISTANCE 150
>       POSITION CC
>       SIZE TINY
>       COLOR 0 0 0
>     END
>   END
>   CLASS
>     EXPRESSION "1"
>     SYMBOL 'interstate_shield'
>     LABEL
>       MINFEATURESIZE 50
>       MINDISTANCE 150
>       POSITION CC
>       SIZE TINY
>       COLOR 255 255 255
>     END
>   END
> END # highway annotation
> LAYER
>   NAME cities
>   TYPE ANNOTATION
>   DATA mcd90py2
>   STATUS ON
>   LABELITEM "city_name"
>   CLASSITEM "city_name"
>   LABELMAXSCALE 500000
>   CLASS
>     EXPRESSION /./
>     COLOR -1 -1 -1
>     LABEL
>       COLOR 0 0 0
>       SHADOWCOLOR 218 218 218
>       SHADOWSIZE 2 2
>       TYPE BITMAP
>       SIZE MEDIUM
>       POSITION CC
>       PARTIALS FALSE
>       BUFFER 2
>     END
>   END
> END
> END # Map File
> Procergs
> BRAZIL
> email : ricmar at pro.via-rs.com.br
More information about the MapServer-users
