itemnquery not returning all results
Robin.Ellis at dnr.qld.gov.au
Tue Sep 19 21:34:40 EDT 2000
Sorry to bother you all, I had a map extent problem.
Rob
> -----Original Message-----
> From: Ellis Robin (Bundaberg)
> Sent: Wednesday, 20 September 2000 8:56
> To: MapSever Users (E-mail)
> Subject: itemnquery not returning all results
> I'm having difficulty getting Mapserver to return all matching records
> from a shapefile when using 'itemnquery'. I use the following code to run
> the process:
> //seqbbggis002/cgi-bin/ms_3.3.003?&map=/data4/WWW/projects/burnett/mgr/qdr
> ag.map&mode=itemnquery&item=geol&value=^Clc$&qlayer=ardsoilsinfo
> Often i'll get only a small subset of the intended records returned, or
> (more distressingly) no matching records found for some valid values.
> I can simulate the same types of queries on the shapefiles in Arcview and
> have no difficulties, so I'm assuming I have a mapserver problem and not a
> shapefile error.
> Can anybody shed some light on what I might be doing wrong?
> We're using version 3.3003
> Thanks
> Rob
> Robin Ellis
> Land Resources Officer
> Department of Natural Resources
> Burnett District
> ph: 07 4131 5771
> fax: 07 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
