Projection - geographic
Daniel Morissette
danmo at videotron.ca
Tue Sep 26 22:59:08 EDT 2000
Ricardo,
I am not familiar with Mandrake Linux specifically, but this looks very
much like a runtime library path problem. The same thing happens on
RedHat Linux when we install the PROJ.4 RPM distributed on
remotesensing.org.
See FAQ #8 in:
http://www2.dmsolutions.on.ca/mapserver/php_mapscript/php_mapscript_faq.html
BTW, on RedHat, the "server error log" is in /var/log/httpd/error_log.
It must be in a similar location on Mandrake I would think.
Good Luck!
Daniel Morissette danmo at videotron.ca
http://pages.infinit.net/danmo/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
Ricardo Wagner Martins wrote:
> Hi all,
> I am running Mandrake Linux 7.0.2, Apache 1.3 and mapserv 3.3.010. I
> have a .shp file in Lat/Lon coordinates and I've been trying to make
> it work without success. Here follow the steps I performed:
> 1) I compiled the Mapserv with the Proj4 option successfully.
> 2) I tried to run my mapfile and an error ocurred.
> 3) I tried to run the sample with this Mapserv as a test and the same
> error ocurred again:
> Internal Server Error
> "The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator, root at localhost and inform
> them of the time the error occurred, and anything you might have done
> that may have caused the error.
> More information about this error may be available in the server error
> log."
> I didn´t find the "server error log" to see "more information".
> I have to say that with the original Mapserv ( without Proj4 option) I
> had no problems with the demo, but with my mapfile. The .gif image (
> layer ) don't come up.
> My questions are:
> 1) Can I work with Mapserv without Proj4 option or I must use the
> statement PROJECTION and in consequence the Mapserv with Proj4 option
> ? I red that if all data is in the same system then you don´t need the
> Proj4 library at all.
> 2) Is the position of statement PROJECTION correct ?
> Thanks in advance for any help.
> PROCERGS
> Brazil
> Here is my mapfile:
> # Start of map file - created Mon Sep 25 16:02:15 2000
> NAME corsan
> STATUS ON
> SIZE 550 370
> SHADESET "/home/httpd/html/ms_corsan/symbols/shade.sym"
> MARKERSET "/home/httpd/html/ms_corsan/symbols/marker.sym"
> LINESET "/home/httpd/html/ms_corsan/symbols/line.sym"
> EXTENT -58.041 -34.084 -49.293 -26.746
> UNITS METERS
> SHAPEPATH "/home/httpd/html/ms_corsan/data"
> IMAGECOLOR 255 255 255
> # Projection definition, consult the PROJ.4 documentation for
> parameter
> PROJECTION
> "proj=utm"
> "ellps=GRS80"
> "zone=15"
> "north"
> "no_defs"
> END
> # Start of web interface definition
> WEB
> IMAGEPATH "/home/httpd/html/tmp/"
> IMAGEURL "/tmp/"
> HEADER corsan_header.html
> TEMPLATE corsan.html
> FOOTER corsan_footer.html
> MINSCALE 1000
> MAXSCALE 1550000
> END #WEB
> # Start of reference map
> REFERENCE
> SIZE 150 160
> IMAGE graphics/reference.gif
> EXTENT -57.644 -33.751 -49.691 -27.080
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END #REFERENCE
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> POSITION UR
> END
> STATUS ON
> END #LEGEND
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END #LABEL
> SIZE 350 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> INTERVALS 10
> STATUS ON
> END #SCALEBAR
> # Start of layer definitions
> LAYER
> NAME rscorsan.shp
> PROJECTION
> "geographic"
> END
> TYPE Polygon
> STATUS on
> HEADER 'rscorsan.shp_header.html'
> QUERY
> TEMPLATE rscorsan.shp_query.html
> END # QUERY
> CLASS
> Name "rscorsan.shp"
> COLOR 41 214 169
> OUTLINECOLOR 0 0 0
> END # CLASS
> END # LAYER
> END # MAPFILE
