Projection - geographic
Ricardo Wagner Martins
ricmar at pro.via-rs.com.br
Tue Sep 26 16:11:23 EDT 2000
Hi all,
I am running Mandrake Linux 7.0.2, Apache 1.3 and mapserv 3.3.010. I
have a .shp file in Lat/Lon coordinates and I've been trying to make it
work without success. Here follow the steps I performed:
1) I compiled the Mapserv with the Proj4 option successfully.
2) I tried to run my mapfile and an error ocurred.
3) I tried to run the sample with this Mapserv as a test and the same
error ocurred again:
Internal Server Error
"The server encountered an internal error or misconfiguration and was
unable to complete your request.
Please contact the server administrator, root at localhost and inform them
of the time the error occurred, and anything you might have done that
may have caused the error.
More information about this error may be available in the server error
log."
I didn´t find the "server error log" to see "more information".
I have to say that with the original Mapserv ( without Proj4 option) I
had no problems with the demo, but with my mapfile. The .gif image (
layer ) don't come up.
My questions are:
1) Can I work with Mapserv without Proj4 option or I must use the
statement PROJECTION and in consequence the Mapserv with Proj4 option ?
I red that if all data is in the same system then you don´t need the
Proj4 library at all.
2) Is the position of statement PROJECTION correct ?
Thanks in advance for any help.
PROCERGS
Brazil
Here is my mapfile:
# Start of map file - created Mon Sep 25 16:02:15 2000
NAME corsan
STATUS ON
SIZE 550 370
SHADESET "/home/httpd/html/ms_corsan/symbols/shade.sym"
MARKERSET "/home/httpd/html/ms_corsan/symbols/marker.sym"
LINESET "/home/httpd/html/ms_corsan/symbols/line.sym"
EXTENT -58.041 -34.084 -49.293 -26.746
UNITS METERS
SHAPEPATH "/home/httpd/html/ms_corsan/data"
IMAGECOLOR 255 255 255
# Projection definition, consult the PROJ.4 documentation for parameter
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=15"
"north"
"no_defs"
END
# Start of web interface definition
WEB
IMAGEPATH "/home/httpd/html/tmp/"
IMAGEURL "/tmp/"
HEADER corsan_header.html
TEMPLATE corsan.html
FOOTER corsan_footer.html
MINSCALE 1000
MAXSCALE 1550000
END #WEB
# Start of reference map
REFERENCE
SIZE 150 160
IMAGE graphics/reference.gif
EXTENT -57.644 -33.751 -49.691 -27.080
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END #REFERENCE
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
POSITION UR
END
STATUS ON
END #LEGEND
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END #LABEL
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
INTERVALS 10
STATUS ON
END #SCALEBAR
# Start of layer definitions
LAYER
NAME rscorsan.shp
PROJECTION
"geographic"
END
TYPE Polygon
STATUS on
HEADER 'rscorsan.shp_header.html'
QUERY
TEMPLATE rscorsan.shp_query.html
END # QUERY
CLASS
Name "rscorsan.shp"
COLOR 41 214 169
OUTLINECOLOR 0 0 0
END # CLASS
END # LAYER
END # MAPFILE
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000926/0421f6cf/attachment.html
