Display query results
bertha amalia serrato de la cruz bertha_bonita at yahoo.com
Tue Sep 26 15:13:18 EDT 2000
Hi list
when i run mapserver, i obtain certain points on a
layer, but when i want obtain information about one
specific point, give me a error..
msQueryUsingPoint():Search returned no result. No
matching record(s) found.
but in others points, of the same layer, i reallly can
obtain information, that''s works good!, i don't
understand what's appening..!!!...
in fact, i changed the TOLERANCE, but not is the
solution.Neither is the EXTENT, because the point that
i have is in northwest of Mexico.
Other question, i had this path.!
SHAPEPATH "/home/httpd/html/geologia/prueba"
and all worked well, but, i changed the files of
directory, and done the changes correctly, but i can't
display the layers ..!! say me can't found them!. I
don't understand, only change the directories name,
then return at the same name, but neither works!..
somebody can give an advice please??..
Thanks!
this is my file.map
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600  #size in pixels of the image
SHADESET /home/httpd/html/geologia/symbols/shade.sym
MARKERSET /home/httpd/html/geologia/symbols/marker.sym
LINESET /home/httpd/html/geologia/symbols/line.sym
EXTENT -118.5 12.25 -85.44 33
UNITS DD   #Decimal Degrees
# de donde va a jalar los datos, shx,shp,dbf
IMAGECOLOR 255 255 255
# Start of web interface definition
WEB
  HEADER /home/httpd/html/geologia/geo_header.html
  TEMPLATE /home/httpd/html/geologia/geo.html
  MINSCALE 100000
  MAXSCALE 10000000
IMAGEPATH "/home/httpd/html/geologia/tmp/"
IMAGEURL "http://pc-simac.cicese.mx/geologia/tmp/"
END
# Start of reference map
REFERENCE
IMAGE /home/httpd/html/geologia/graphics/Mex_Ref.gif
   STATUS ON
  COLOR -1 -1 -1
  OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
  KEYSIZE 18 12
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
  STATUS ON
END
# Start of scalebar
SCALEBAR
  LABEL
    COLOR 0 0 0
    SIZE SMALL
  END
  SIZE 350 5
  COLOR 255 255 255
  BACKGROUNDCOLOR 0 0 0
  OUTLINECOLOR 0 0 0
  UNITS MILES
  INTERVALS 5
  STATUS ON
END
# Start of layer definitions
LAYER
  NAME MexicoMdt2
  TYPE RASTER
  STATUS ON
  DATA
/home/httpd/html/geologia/graphics/MexicoMDT2.tif
#  OFFSITE 0
END
LAYER
  NAME states
   TYPE POLYGON
   STATUS ON
   DATA states
   TOLERANCE 5
   CLASS
     SYMBOL 0
     OUTLINECOLOR 0 0 0
     COLOR 248 248 95
   END
   QUERY
     TEMPLATE states.html
   END
END
LAYER
   NAME roads
  TYPE POLYLINE
 STATUS ON  #DEFAULT
 DATA roads
   CLASS
    SYMBOL 0
   OUTLINECOLOR 0 0 0
   COLOR 255 0 0
   END
END
LAYER
   NAME drainage
  TYPE LINE
 STATUS ON  #DEFAULT
 DATA drainage
   CLASS
    SYMBOL 0
   OUTLINECOLOR 0 0 0
   COLOR 0 0 255
   END
END
LAYER
   NAME adamellite
   TYPE POINT  #ANNOTATION
   STATUS ON
   DATA /home/httpd/html/geologia/geocronos/adamellite
   CLASS
     SIZE 5
     COLOR 45 0 0
     SYMBOL 4
     LABEL
       BACKGROUNDCOLOR 0 0 255
       COLOR 30 94 94
       TYPE BITMAP
      #JUSTIFY CENTER
      SIZE GIANT
      POSITION AUTO
      WRAP " "
    END # Label
   END  #class
END  #layer
LAYER
   NAME basalt
   STATUS ON
     DATA
/home/httpd/html/geologia/geocronos/Basalt/basalt
   TOLERANCE 20
   CLASS
     NAME "basalt"
     SIZE 8
     COLOR 0 255 0
     SYMBOL 4
   END  #class
   QUERY
     TEMPLATE basalt.html
    END
      END  #layer basalt
LAYER
   NAME granodiorite
   STATUS ON
     DATA
/home/httpd/html/geologia/geocronos/Basalt/granodiorite
   TOLERANCE 20
   CLASS
     NAME "granodiorite"
     SIZE 8
     COLOR 255 0 0
     SYMBOL 4
   END  #class
   QUERY
     TEMPLATE granodiorite.html
    END
      END  #layer granodiorite
LAYER
  NAME cities
  TYPE ANNOTATION
  STATUS ON
  DATA cities
  TOLERANCE 10
  LABELITEM "name"
 CLASS
    SIZE 8
    COLOR 0 0 255
    SYMBOL 6
    LABEL
      BACKGROUNDCOLOR 200 255 255
      COLOR 30 94 94  # color del texto
      FONT COMIC_SANS
      TYPE BITMAP
      SIZE GIANT
      POSITION AUTO
      WRAP " "
    END # Label
 END # Class
  QUERY
    TEMPLATE cities.html
  END # Query
END # Layer
END # Map File
    Lic. Ciencias Computacionales Bertha A. Serrato
    bserrato at cicese.mx
    CICESE,División de Ciencias de la Tierra.
    Ensenada, B.C.
__________________________________________________
Do You Yahoo!?
Send instant messages & get email alerts with Yahoo! Messenger.
http://im.yahoo.com/
