Mapserv and SDE
Sullivan, James R.
SullivanJ at nima.mil
Wed Sep 27 09:06:55 EDT 2000
I am running Mapserv with the SDE option and had initial problems getting
everything built, but now works fine. Steve tells me that Version 3.3.0011
does not yet support annotation or query. You can however use the
EXPRESSION function within the class object to limit your retrievals.
Mapserv/SDE will automatically do a geographic query based on the current
extent displayed in your mapserv window. Steve promises additional
functionality soon. I have been experimenting with Mapscript/Perl CGI to
find some work arounds. Have no results due to lack of time. If anyone has
done some Mapscript work with SDE please let us know.
Jim Sullivan
-----Original Message-----
From: Brian Fischer [SMTP:Brian.Fischer at co.sherburne.mn.us]
Sent: Tuesday, September 26, 2000 9:19 AM
To: johnh at erin.gov.au; mapserver-users at lists.gis.umn.edu
Subject: Re: Mapserv and SDE
I like John's suggestion for making an option to make the outline of
the area of interest for the reference map thicker. When developing my
application I thought this would be a nice option. Sometimes it is hard to
see the outline.
Brian
>>> John Hockaday <johnh at erin.gov.au> 09/25/00 09:52PM >>>
This is probably just for Steve Lime but I'll send it to this list
just
in case someone else knows the answers.
I using MapServer Version 3.3.011 compiled for "-FreeType -TIFF
-EPPL7
-JPEG -SDE" using Solaris 2.7. I have been able to build up the map
file, template and query templates with wonderful results. I have
found the development of interfaces very easy with the templates
and map files. The examples at URL:
http://arachnid.dnr.state.mn.us/ms_test/index.html are an absolute
necessity.
I have some lacking functionality with the SDE layers which I
believe
will be fixed soon? They are:
1. I can't perform annotation with the SDE layers. An error
message is produced telling me that that is not yet
available.
2. When I produce a QUERYMAP the SDE layers are not drawn.
3. Layers with multiple, complicated polygons sometimes seem
to
have the polygons cut off. (I'm not sure if other people
are
aware of this.)
I was also wondering if there was an ERRORTEMPLATE, or something
like
that, in the map file that allows me to produce a more friendly HTML
message if a user doesn't select a querable point during a query.
Mapserv currently returns an
"msQueryUsingPoint(): Search returned no results. No
matching
record(s) found."
error. I would like it to report something like, "Please go back to
the map interface and click on a point ... etc.". It already has
HEADER and FOOTER in the LAYER object as well as a TEMPLATE in the
QUERY object so an ERRORTEMPLATE would compliment the functionality.
I would also like to make the thickness of the OUTLINECOLOR element
of
the reference box, in the REFERENCE object, a little thicker so that
it
can be more easily seen when the area of interest is very small on
the
reference map. I would probably have to edit the C code to do this
myself so I was wondering if someone could give me some line numbers
or
keywords to search for so that I can make these changes. Unless,
hope
hope hope, someone has already made these changes?
Thanks in advance for all your help.
Johnh
