georeferencing the gif image
Pericles S. Nacionales pnaciona at gis.umn.edu
Wed Sep 27 19:52:26 EDT 2000
Folks,
Another tip:  I usually export in WMF format then resize in Adobe
Illustrator (other vector drawing programs should work).  The graphic
produced in WMF format is vector and scales nicely to a smaller size.  If
you export in JPEG format, you probably should first scale ArcView's View
window to the size you want.  Then export and get the extent.  This way, you
won't have to resize the raster graphic and just need to convert to GIF (or
PNG).
-Perry N.
----- Original Message -----
To: "MAPSERVER" <mapserver-users at lists>; "Tsering Wangyal Shawa"
<shawatw at Princeton.EDU>
Sent: Wednesday, September 27, 2000 6:36 PM
Subject: Re: georeferencing the gif image
> Wangyal,
> In ArcView, you can get the extent of a reference map by clicking on
"View",
> then "Properties".  Once you're in the "View Properties" window, select
the
> "Area of Interest" button--this will give you another window.  From the
new
> window, select "Display" from the "Set AOI to:" drop-down box--this will
> give you the extent of the currently displayed view.  The EXTENT values go
> "LEFT BOTTOM RIGHT TOP"
> You can then export the current display (view) as either WMF or JPEG, then
> resize and save as GIF (or PNG) to be used as reference map.
> Good luck!
> -Perry N.
