georeferencing the gif image
Michael Anderson m_anderson14 at hotmail.com
Wed Sep 27 19:57:45 EDT 2000
I had a script that reports the coordinates, so I put it in an extension.
The extension is called "Bounding Box". It will add a button with a box to
the end of the button bar. Click it and it will pop up the coordinates for
the current view extent in a message box. You can copy the coordinates from
the message box and paste them into your map file. I have had .avx files get
corrupted by email, so I zipped it. Hope it is useful to someone.
Mike
>From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
>To: <mapserver-users at lists.gis.umn.edu>, <shawatw at Princeton.EDU>
>Subject: Re: georeferencing the gif image
>Date: Wed, 27 Sep 2000 17:26:10 -0500
>I generally use the mapserver standalone utility "shp2img" to create a base
>image. That is, I use a stripped down map file to build an image of say,
>state boundaries (noting the extent used to create it). Then I pull that
>image into photoshop and make it look pretty there. You can scale the
>image, but can't crop it without screwing up the extent you saved
>initially. Then, with the image done you can create the REFERENCE object in
>your main map file with EXTENT equal to the value noted above.
>As far as I know there is no easy way to get the bbox for an image exported
>from ArcView. If someone knows otherwise please let the list know.
>Steve
> >>> Tsering Wangyal Shawa <shawatw at Princeton.EDU> 09/27/00 16:44 PM >>>
>Now that I managed to run demo version of Mapserver. I am trying to create
>mapserver with my own data set. I want to know, what is the best way to
>create a georeference gif image file for backgroup (reference) map.
>This is what I did: I open a map in ArcView and saved that map in a jpg
>format before I saved the file I collected a general georeference info from
>the map. After the image was saved in jpg I open that image in photoshop
>and saved again in gif format. I used this gif image as reference image and
>used georeference info that I collected the original  map (before I saved
>it as jpg image) on REFERENCE EXTENT. But this is not working. I can not
>overlay any thing on the map once I open it in the mapserver. What is the
>problem and how to fix it.
>I try to use tif map with georeference info as reference map but it did not
>worked.
>Thank you advance for your help.
>-Wangyal
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000927/72f91e00/bbox.bin
