Change Output Image Resolution
Stephen Lime
steve.lime at dnr.state.mn.us
Tue Apr 3 14:43:01 EDT 2001
Nope, the 72 DPI is a constant (although you could change it and recompile). Since all that the DPI value affects is scale you could fake a higher resolution by doing the following in MapScript:
- do a $map->prepare() (this calculates scale)
- change $map->{scale} to reflect your desired output resolution
- now loop through the layers and do a $layer->draw()
Steve
>>> Düster Horst <Horst.Duester at bd.so.ch> 04/03/01 08:34 AM >>>
Hi all
Is it possible to change the resolution of an MapServer output image from 72
dpi to higher resolution via MapScript??
Best regards
Dr. Horst Düster
Leiter
GIS Koordinationsstelle SOGIS
Rötihof
4500 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
mailto:horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
http://www.so.ch <http://www.so.ch/>
