[mapserver-users] ecw
kenboss kenboss at dilbert.dnr.state.mn.us
Tue Apr 24 10:23:17 EDT 2001
Now this is welcome news.  Our shop has to date steered clear of ECW owing to
its apparent marriage to Microsoft operating systems.  Given that we are
primarily a Unix shop, and in particular that our web server is Unix-based,
there didn't seem to be any reasonable means of fitting ECW into the mix.  Can I
assume that GDAL support for ECW means that we will (finally) be able to serve
ECW images from Unix servers?
--Ken Boss
> Frank Warmerdam wrote:
> Is there direct ECW support in MapServer?
> In any event, there is ECW support in GDAL and GDAL support has been
> incorporated into the current CVS tree for MapServer.  If you are brave, you
> could build the current CVS MapServer, and build GDAL (carefully enabling
> ECW support) to get this capability.
> More information on GDAL is available at:
>   http://www.remotesensing.org/gdal/
> The downside is that I have had problems with the GDAL ECW supporting hanging
> processes on exit(), presumably because of some sort of threads issue on
> exit.  So I don't know that this is ready for prime time yet.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
