[mapserver-users] label symbol size vs. label font size
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Aug 20 12:27:12 EDT 2001
If the shields are images then they can't be scaled and size is ignored. The label size and symbol
size are not tied together in anyway. The best way to deal with 3 digits would be to have 2 versions
of the symbol (i.e. 2 gifs) and then use the length operator in an expression. You could also change
font size based on length. For example:
CLASS
# class for 2 digit labels
EXPRESSION (length('[HWYNUM]') eq 2)
END
CLASS
# class for 2+ digit labels (note: no expression)
END
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Chad Nielsen" <cnielsen at co.tillamook.or.us> 08/16/01 01:20PM >>>
I'm having trouble adjusting the size of my highway shield symbols relative
to the label font size. Seems I can only make the highway shields bigger if
I make the font bigger, i.e. by increasing the SIZE attribute of the LABEL
object. Problem is I have 3-digit highway numbers which makes the text go
outside the shield boundary. If I increase the SIZE attribute of the CLASS
object nothing happens. How can I make the shield bigger without making the
label font bigger? Or, is there some other trick to getting 3-digits to fit
inside a shield? here is what I have in my map file:
LAYER
NAME highwayshields
DATA 'e:\gisweb\data\transportation\shapes\nwohwy'
STATUS ON
TYPE ANNOTATION
LABELITEM "HWYNUM"
CLASS
COLOR 0 0 0
SIZE 18
SYMBOL 3
OUTLINECOLOR 0 0 0
LABEL
SIZE 10
MINDISTANCE 200
COLOR 0 0 0
BACKGROUNDCOLOR -1 -1 -1
TYPE TRUETYPE
FONT verdana-bold
POSITION CC
END #LABEL
END # CLASS
END # LAYER
TIA,
Chad
Chad M. Nielsen, GIS Programmer/Analyst
Tillamook County Performance Partnership (TCPP)
Tillamook Coastal Watershed Resource Center (TCWRC)
GIS: http://gisweb.co.tillamook.or.us
TCPP: http://www.co.tillamook.or.us/gov/Estuary/homepage.htm
TCWRC: http://www.tcwrc.org
