[mapserver-users] java MapScript
Scott Shealy sshealy at e811.com
Wed Dec 5 10:41:55 EST 2001
I have gotten it to compile... I had to rip out the SWIG generated exception
handeling code and rename all method that genrated the stub
getClass(conflicts with java.lang.Object.getClass) to getClass_.  That did
the trick. I think the SWIG genrated error code only handle C runtime
exceptions so it is not that big a deal. I have been meaning to go back and
see why it will not compile but I have not had a chance yet.. As I remember
it was complaining about some jClass object(a JNI object) in the error
handling code that look perfectly fine to me...
Make sure when you compile it that you use all the same compiler flags that
you compile the mapserver(libmap.a) with or you will have all kinds of fun
runtime errors(related to memory errors)
Scott Shealy
