[mapserver-users] Stand alone application
Stephen Lime steve.lime at dnr.state.mn.us
Wed Dec 5 16:17:24 EST 2001
The code at http://maps.dnr.state.mn.us/javascript/mapserv.js may be of interest. It's for 3.4 and would require only minimal updates for 3.5 since there was a slight change in how extents are calculated so as to better match the OGC WMT specs. I use that to do all client-side coordinate management for the LandView interface...
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Pedro A. Carrasco" <pcarrasco at iver.es> 12/05/01 10:46AM >>>
	Hi all,
	I'm developing a Delphi 6 CLX Control to work with MapServ. Currently I can
do FullExtent, ZoomIn, ZoomOut, Pan and Identify.
	My problem is that I want to know the extent of the map. The mode=map only
returns the image correspondig to the map, and when I want to make the zoom
operations or pan, I must give the new extent to the map. I listen anything
that someone have source code in Java/Javascript to made this calculations,
can someone help me. Have anyone examples of how to made this.
	Thanks in advance.
	Regards.
Pedro
