[mapserver-users] very frusterated newbie! heh
Grant Marblestone
GrantM at ATSER.com
Wed Dec 5 16:28:50 EST 2001
So you suggest i assume that my mapserv 3.3 is too old and goto 3.4 right?
Thats all i can figure out, because the .shp files should be fine correct?
Thanks again@@@@!
Grant
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <GrantM at ATSER.com>; <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, December 05, 2001 2:27 PM
Subject: Re: [mapserver-users] very frusterated newbie! heh
Wow, your working with some real old mapfiles and I'm assuming a new version
of the software. The LABELOVERLAP parameter hasn't been supported in years.
Were'd you get the test data and application?
First thing to do is get you a current version of the source/binaries and
whatever demo you're trying.
As for shapefiles, you must keep the shp, shx and dbf files. The others are
spatial index files that the MapServer can't use.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
