[mapserver-users] very frusterated newbie! heh
Pericles S. Nacionales pnaciona at gis.umn.edu
Wed Dec 5 16:56:51 EST 2001
Dude!  No need to be rude.  If you don't want the hassle of upgrading to
3.5, just remove the LABELOVERLAP parameter on your map file.  If you are
using MapServer 3.3, the map file reference is still available at
http://mapserver.gis.umn.edu/mapfile.html.
I would say that you really ought to consider upgrading as most users in
this listserv won't be able to help you with the older stuff.
Good luck!
Perry N.
> -----Original Message-----
> From: owner-mapserver-users at lists [mailto:owner-mapserver-users at lists]On
> Behalf Of Grant Marblestone
> Sent: Wednesday, December 05, 2001 3:29 PM
> To: Grant Marblestone; mapserver-users at lists
> Subject: Re: [mapserver-users] very frusterated newbie! heh
> So you suggest i assume that my mapserv 3.3 is too old and goto 3.4 right?
> Thats all i can figure out, because the .shp files should be fine correct?
> Thanks again@@@@!
> Grant
> ----- Original Message -----
> From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
> To: <GrantM at ATSER.com>; <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, December 05, 2001 2:27 PM
> Wow, your working with some real old mapfiles and I'm assuming a
> new version
> of the software. The LABELOVERLAP parameter hasn't been supported
> in years.
> Were'd you get the test data and application?
> First thing to do is get you a current version of the source/binaries and
> whatever demo you're trying.
> As for shapefiles, you must keep the shp, shx and dbf files. The
> others are
> spatial index files that the MapServer can't use.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
