[mapserver-users] performance problem with PostGIS layer
simon mercier
simon.mercier at fadq.qc.ca
Fri Dec 7 09:56:13 EST 2001
hi,
I have performance problem with my PostGIS layer in mapserver.. It's
slow... vvvery slow, when zoom in, zoom out and pan. I'am new with
PostgreSQL, PostGIS, MapServer and realy don't know where to look for
this problem! I have a table of 392000 row of polygon with oid and GiST
index . I have a debian server with a 933 CPU and 128 of RAM...
--I have good result when retrieving data with spatial SQL query :
explain select count(*) from pclp_s where the_geom &&
GeometryFromText('BOX3D(-72.15 46.43, -72.13 46.45)'::BOX3D,-1)
Aggregate (cost=8.94..8.94 rows=1 width=0)
-> Index Scan using idx_geom_pclp_s on pclp_s (cost=0.00..8.93
rows=2 width=0)
--With the same box, (i.e. EXTENT -72.15 46.43 -72.13 46.45 in map
file) it take 80 sec for display image in IE with MapServer...
--A look on status server indicate postmaster take all CPU:
14:51:39 up 1 day, 23:31, 5 users, load average: 0.69, 0.29, 0.10
60 processes: 56 sleeping, 4 running, 0 zombie, 0 stopped
CPU states: 49.1% user, 44.7% system, 0.0% nice, 6.2% idle
Mem: 126060K total, 122584K used, 3476K free, 1380K buffers
Swap: 248968K total, 19516K used, 229452K free, 71440K cached
PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME COMMAND
7255 postgres 18 0 3920 3920 3236 R 85.6 3.1 0:13 postmaster
7254 www-data 9 0 3080 3080 1876 S 0.0 2.4 0:00 mapserv
7253 root 11 0 992 992 776 R 0.3 0.7 0:00 top
It is a server harware problem or a soft setup problem? There is
someting to do?
regard
Simon Mercier
Technicien en Géomatique
Direction des technologies de l'information
La Financière agricole du Quebec
5825, rue Saint-Georges
Lévis, Québec,Canada G6V 4L2
http://www.fadq.qc.ca/
