[mapserver-users] performance problem with PostGIS layer
Pericles S. Nacionales
pnaciona at gis.umn.edu
Fri Dec 7 10:59:50 EST 2001
Simon,
I was just playing with PostGIS and MapServer, using Steve Lime's demo data
(I converted using the shp2pgsql utility), and didn't notice too much of a
performance difference. I'm using RedHat 7.2 and AMD K6-2 500Mhz cpu with
384Mb RAM... Perhaps your database is substantially bigger than mine. Or,
perhaps you ought to add a bit more RAM on your machine? There are other
database admin stuff that can help you speed things up a bit but increasing
the physical memory will make those things help you even more. Check
PostgreSQL's web site for the administrator's guide.
Try my demo at http://128.101.73.155/ms_demo/demo_init.html. It looks just
like the "normal" demo except the data is stored as PostGIS data. (It's a
little sluggish right now as I'm doing some "real" work over the net. :)
-Perry N.
> -----Original Message-----
> From: owner-mapserver-users at lists [mailto:owner-mapserver-users at lists]On
> Behalf Of simon mercier
> Sent: Friday, December 07, 2001 8:56 AM
> To: mapserver
> Subject: [mapserver-users] performance problem with PostGIS layer
> hi,
> I have performance problem with my PostGIS layer in mapserver.. It's
> slow... vvvery slow, when zoom in, zoom out and pan. I'am new with
> PostgreSQL, PostGIS, MapServer and realy don't know where to look for
> this problem! I have a table of 392000 row of polygon with oid and GiST
> index . I have a debian server with a 933 CPU and 128 of RAM...
> --I have good result when retrieving data with spatial SQL query :
> explain select count(*) from pclp_s where the_geom &&
> GeometryFromText('BOX3D(-72.15 46.43, -72.13 46.45)'::BOX3D,-1)
> Aggregate (cost=8.94..8.94 rows=1 width=0)
> -> Index Scan using idx_geom_pclp_s on pclp_s (cost=0.00..8.93
> rows=2 width=0)
> --With the same box, (i.e. EXTENT -72.15 46.43 -72.13 46.45 in map
> file) it take 80 sec for display image in IE with MapServer...
> --A look on status server indicate postmaster take all CPU:
> 14:51:39 up 1 day, 23:31, 5 users, load average: 0.69, 0.29, 0.10
> 60 processes: 56 sleeping, 4 running, 0 zombie, 0 stopped
> CPU states: 49.1% user, 44.7% system, 0.0% nice, 6.2% idle
> Mem: 126060K total, 122584K used, 3476K free, 1380K buffers
> Swap: 248968K total, 19516K used, 229452K free, 71440K cached
> PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME COMMAND
> 7255 postgres 18 0 3920 3920 3236 R 85.6 3.1 0:13 postmaster
> 7254 www-data 9 0 3080 3080 1876 S 0.0 2.4 0:00 mapserv
> 7253 root 11 0 992 992 776 R 0.3 0.7 0:00 top
> It is a server harware problem or a soft setup problem? There is
> someting to do?
> regard
> Simon Mercier
> Technicien en Géomatique
> Direction des technologies de l'information
> La Financière agricole du Quebec
> 5825, rue Saint-Georges
> Lévis, Québec,Canada G6V 4L2
> http://www.fadq.qc.ca/
