[mapserver-users] MAP File Question
Daniel Morissette
morissette at dmsolutions.ca
Fri Dec 7 15:35:01 EST 2001
Stephen Woodbridge wrote:
> I have a question on how CLASSs work in the MAP file. Specifically in
> the following example does the CLASS section work like a switch
> statement int C with a break at each END? Such that if NAME = /^State
> Hwy / then does it skip the rest of the CLASSs. Or such that I could put
> a CLASS at the bottom with no EXPRESSION that could be used as a default
> CLASS if non above were executed?
Yes, you can put a class with no expression at the end to catch any
shape that didn't match any of the previous classes. If I remember
well, this works only with MapServer 3.5 ... older versions of MapServer
didn't like us doing that (it would crash on the null expression).
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
