[mapserver-users] MAP File Question
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Dec 7 14:27:21 EST 2001
I have a question on how CLASSs work in the MAP file. Specifically in
the following example does the CLASS section work like a switch
statement int C with a break at each END? Such that if NAME = /^State
Hwy / then does it skip the rest of the CLASSs. Or such that I could put
a CLASS at the bottom with no EXPRESSION that could be used as a default
CLASS if non above were executed?
I hope this makes sense to you.
-Steve
LAYER
NAME highways
MAXSCALE 600000
STATUS ON
DATA majroads
TYPE ANNOTATION
LABELITEM "RTE_NUM"
CLASSITEM "NAME"
CLASS
EXPRESSION /^State Hwy /
COLOR 0 0 0 # dummy color
SYMBOL 'state_highway_shield'
LABEL
MINFEATURESIZE 25
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION /^US Hwy /
SYMBOL 'us_highway_shield'
LABEL
MINFEATURESIZE 25
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION /^I-/
SYMBOL 'interstate_shield'
LABEL
MINFEATURESIZE 25
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
END # highway annotation
