[mapserver-users] Labels for streets
Hankley, Chip
Chip.Hankley at GASAI.Com
Mon Dec 10 13:46:40 EST 2001
> How do you
> 1) get street labels to match the angle of the street
> (implement rotated fonts)
In the MapServer TestSuite, there is a great example of labeling contours.
This process works well with streets too.
http://maps.dnr.state.mn.us/cgi-bin/mapserv?map=/usr/local/www/docs/mapserve
r_demos/tests/auto_rotate/contours/test.map
Basically, you are going to specify ANGLE AUTO in the label definition.
>, and 2) suppress duplicate labels for every street segment?
I would do some work on the source data... essentially, the labeling is
going to try to label every INDIVIDUAL feature. I don't know that there is a
way to supress duplicates. The easiest way would be to make sure that all of
your line segments that are the same name are "dissolved" into one line.
> While we're at it, is there a way to make the border of a polygon more
than one pixel thick?
Sure, you need to specify a symbol definition, either in a symbol file that
you point to in the header, or in the SYMBOL section of the mapfile.
Here's is a simple symbol definition for a line, we'll make it thick in the
layer definition by using the SIZE feature:
SYMBOL
NAME 'polygon_outline'
TYPE ELLIPSE
POINTS 1 1 END
FILLED
END
....(some more map file)
LAYER
NAME "My_Polygon_Shapefile"
STATUS DEFAULT
DATA \My_Polygon_Shapefile
CLASSITEM CODE
TYPE POLYLINE
CLASS
Name 'SomeClassName'
TEMPLATE "ttt"
EXPRESSION ''
SYMBOL 'polygon_outline'
SIZE 3
COLOR 255 0 0
END # CLASS
END # LAYER
Cheers!
Chip
