[mapserver-users] .shp ArcViewFormat
Luca Pescatore
info at pescatoreluca.com
Thu Dec 13 07:15:17 EST 2001
after a small test with php and demo map i'm trying to read some arcview
files.
It doesn't work, i have changed only sourcetype.
From "DATA twprgpy3" to "DATA Entertn"
I'm using Unix Server with Apache and PHP 4.0.6.
What's wrong ?
Another little question, how can i create or modify my .shp files ?
Best Regards,
Luca Pescatore
# Start of map file
NAME DEMO
STATUS ON
SIZE 400 300
#EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
#END
# Start of web interface definition
WEB
HEADER map_header.html
TEMPLATE map.html
FOOTER map_footer.html
MINSCALE 1000
MAXSCALE 15500
IMAGEPATH "/usr/local/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
# LOG "demo.log"
END
QUERYMAP
SIZE 300 300
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 75 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME county
TYPE POLYGON
STATUS DEFAULT
DATA ctybdpy2
CLASSITEM 'cty_name'
CLASS
EXPRESSION 'Itasca'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS # every other county in the state
EXPRESSION /./
COLOR 255 255 255
END
END
LAYER
NAME cities
TYPE POLYGON
DATA mcd90py2
STATUS ON
CLASSITEM city_name
CLASS
NAME "Cities & Towns"
EXPRESSION /./
COLOR 255 225 90
END
END
# Griglie delle Province
LAYER
NAME townships
TYPE POLYGON
DATA twprgpy3
STATUS ON
CLASS
SYMBOL 'circle'
SIZE 2
NAME 'Townships'
OUTLINECOLOR 181 181 145
END
END
LAYER
NAME lakes
TYPE POLYGON
STATUS ON
DATA lakespy2
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "lakespy2.html"
COLOR 49 117 185
END
HEADER "lakespy2_header.html"
FOOTER "lakespy2_footer.html"
TOLERANCE 3
END # lakes
LAYER
NAME streams
TYPE LINE
STATUS ON
DATA dlgstln2
CLASS
NAME "Streams"
TEMPLATE "dlgstln2.html"
COLOR 49 117 185
END
HEADER "dlgstln2_header.html"
FOOTER "dlgstln2_footer.html"
TOLERANCE 5
END
LAYER
NAME roads
MAXSCALE 300000
STATUS ON
DATA ctyrdln3
TYPE LINE
CLASS
COLOR 0 0 0
END
END
LAYER
NAME roads
MAXSCALE 300000
STATUS ON
DATA ctyrdln3
TYPE ANNOTATION
LABELITEM "road_name"
CLASS
COLOR 255 255 255
#SYMBOL 'ctyhwy.gif'
LABEL
MINFEATURESIZE 40
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
END # county road annotation
LAYER
NAME roads
MAXSCALE 600000
STATUS ON
DATA majrdln3
TYPE LINE
CLASS
NAME "Roads"
COLOR 0 0 0
END
END # highways
LAYER
NAME roads
MAXSCALE 600000
STATUS ON
DATA majrdln3
TYPE ANNOTATION
LABELITEM "road_num"
CLASSITEM "road_class"
CLASS
EXPRESSION "3"
COLOR 0 0 0 # dummy color
#SYMBOL 'sthwy.gif'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "2"
#SYMBOL 'ushwy.gif'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION "1"
#SYMBOL 'interstate.gif'
LABEL
MINFEATURESIZE 50
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
END # highway annotation
LAYER
NAME cities
TYPE ANNOTATION
DATA mcd90py2
STATUS ON
LABELITEM "city_name"
CLASSITEM "city_name"
LABELMAXSCALE 500000
CLASS
EXPRESSION /./
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
END
END # Map File
