[mapserver-users] .shp ArcViewFormat
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 13 09:07:20 EST 2001
Luca Pescatore wrote:
> Hi,
> after a small test with php and demo map i'm trying to read some
> arcview files.
> It doesn't work, i have changed only sourcetype.
> From "DATA twprgpy3" to "DATA Entertn"
> I'm using Unix Server with Apache and PHP 4.0.6.
> What's wrong ?
Luca,
The Entertn.shp/shx files seem to be corrupt. The file length section contains
0x00000000 (24 bytes into the file) which results in an internal calculation
of there being -12 records.
How were your shapefiles prepared?
> Another little question, how can i create or modify my .shp files ?
There are a number of ways. You can do it from within PHP, or write a
C program against my Shapelib, use a GIS package like ArcView, etc.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
