[mapserver-users] Mapplet under 3.5 (FWD)
Armin Burger armin.burger at territoriumonline.com
Fri Dec 14 18:20:42 EST 2001
Stuart,
It should have to do with the PNG output. I think that only Netscape 6
(using the 1.3 java plugin) will show png files in a java applet. So you'll
have to use mapserver with GIF output. That should work fine then.
Armin
> ------------- Begin Forwarded Message -------------
> From: Stuart.Row at brs.gov.au
> To: mapserver-info at lists.gis.umn.edu
> Subject: Mapplet under 3.5
> Date: Fri, 14 Dec 2001 11:51:01 +1100
> MIME-Version: 1.0
> I have just upgraded an application using the Mapplet applet from
> 3.3 to 3.5. Everything appears to be working except the map image
> does not display. I have checked the output PNG file (as listed
> in the source HTML code) and it is fine. For some reason my
> application just won't dipslay it. Are there any issues with
> running the Mapplet applet under 3.5 that I need to allow for?
> Thanks in advance
> Stuart Row
> Bureau of Rural Sciences
> PO Box E11
> Kingston ACT
> Ph: +61 6272 4640   Fax: +61 6272 4687
> Email: stuart.row at brs.gov.au
> ------------- End Forwarded Message -------------
