[mapserver-users] Mapplet under 3.5 (FWD)
Ed McNierney ed at topozone.com
Fri Dec 14 18:40:44 EST 2001
Armin -
Actually, any browser that can run Java 2 (a/k/a JRE 1.3 or greater)
will provide PNG support to applets.  You don't need to go to Netscape 6
to do that, but the applet, of course, has to take advantage of that
support.
	- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Armin Burger [mailto:armin.burger at territoriumonline.com]
Sent: Friday, December 14, 2001 6:21 PM
To: mapserver-users at lists.gis.umn.edu; Stuart.Row at brs.gov.au
Subject: Re: [mapserver-users] Mapplet under 3.5 (FWD)
Stuart,
It should have to do with the PNG output. I think that only Netscape 6
(using the 1.3 java plugin) will show png files in a java applet. So
you'll
have to use mapserver with GIF output. That should work fine then.
Armin
> ------------- Begin Forwarded Message -------------
> From: Stuart.Row at brs.gov.au
> To: mapserver-info at lists.gis.umn.edu
> Subject: Mapplet under 3.5
> Date: Fri, 14 Dec 2001 11:51:01 +1100
> MIME-Version: 1.0
> I have just upgraded an application using the Mapplet applet from
> 3.3 to 3.5. Everything appears to be working except the map image
> does not display. I have checked the output PNG file (as listed
> in the source HTML code) and it is fine. For some reason my
> application just won't dipslay it. Are there any issues with
> running the Mapplet applet under 3.5 that I need to allow for?
> Thanks in advance
> Stuart Row
> Bureau of Rural Sciences
> PO Box E11
> Kingston ACT
> Ph: +61 6272 4640   Fax: +61 6272 4687
> Email: stuart.row at brs.gov.au
> ------------- End Forwarded Message -------------
