[mapserver-users] [Fwd: Security]
Ed McNierney
ed at topozone.com
Tue Dec 18 17:09:58 EST 2001
Mr. Diaz -
No. You should configure a new temporary map file directory on your
server that has nothing in it but MapServer output files. The server
process (i.e. the mapserv CGI program) needs to have write access to
that directory, but if the only thing in it is MapServer-generated map
files, that should not pose a risk to any other files on your server.
You should always review your server configuration carefully to make
sure you have not set more generous permissions than you intended.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Jamie Smedsmo [mailto:jsmedsmo at gis.umn.edu]
Sent: Tuesday, December 18, 2001 4:41 PM
To: mapserver-users
Cc: Diaz, William
Subject: [mapserver-users] [Fwd: Security]
-------- Original Message --------
Subject: Security
Date: Tue, 18 Dec 2001 13:22:17 -0800
From: "Diaz, William" <mailto:W.DIAZ at CGIAR.ORG> <W.DIAZ at CGIAR.ORG>
To: "'mdp at lists.gis.umn.edu'" <mailto:'mdp at lists.gis.umn.edu'>
<mdp at lists>
Tell me please
using the tmp directory (with mapserver) can produce some risk to our
servers and networks?
William
William Diaz S. email: w.diaz at cgiar.org <mailto:w.diaz at cgiar.org>
