[mapserver-users] getSymbol(): (BUFFER):395 error
Tim Sutton
sutton_t at giug.net
Wed Dec 19 08:37:50 EST 2001
Hi
I have just upgraded my cvs to get up to date with 3.5 stable. My last
build was made about 1.5 months back. I am using phpmapscript with php
as a CGI. When I use the version built from todays cvs update, I get
an error reading my map file:
Warning: MapServer Error in getSymbol(): (BUFFER):(395)
It is the same mapfile I was using successfully with the previous cvs
build. Can anyone tell me what is going on? The map file is included
in full below.
Thanks
Tim
Tim Sutton WRc plc
Consultant, GIS Solutions Group Frankland Road
Direct line: +44 (0) 1793 865056 Blagrove
Switchboard: +44 (0) 1793 865000 Swindon
Fax: +44 (0) 1793 865001 Wiltshire SN5 8YF
United Kingdom
WRc - Solutions for Water, Waste and the Environment
# Start of map file
NAME europe.map
SIZE 550 370
EXTENT -11.576 36.060 29.804 69.777
#File Bounds: ( -11.576, 36.060,0,0)
# to ( 29.804, 69.777,0,0)
SYMBOLSET symbols/symbols.sym
IMAGEQUALITY 86
IMAGECOLOR 172 202 236
# IMAGECOLOR 207 232 249
UNITS dd
FONTSET 'fonts/ms_fontset'
SHAPEPATH '/shape/'
# Start of web interface definition
WEB
TEMPLATE 'mapdisplay.html'
IMAGEPATH '/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END #WEB
# Start of reference map
REFERENCE
SIZE 150 160
IMAGE /ms_europe/ref_map.jpg
EXTENT 217356.950 465307.700 252617.812 504843.660
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END #REFERENCE
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 172 202 238
POSITION UR
END
STATUS ON
END #LEGEND
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END #LABEL
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
INTERVALS 10
STYLE 1
STATUS ON
END #SCALEBAR
QUERYMAP
STYLE HILITE
COLOR 0 128 128
END
# Start of layer definitions
#Layers draw in the order listed ie. last listed layers are on top
#shpdump EEA_region.shp |head
#Shapefile Type: Polygon # of Shapes: 51
#File Bounds: ( -180.000, 27.637,0,0)
# to ( 180.000, 81.852,0,0)
#shpdump NONEEA_region.shp |head
#Shapefile Type: Polygon # of Shapes: 8
#File Bounds: ( -73.054, 3.493,0,0)
# to ( 134.774, 83.624,0,0)
#shpdump STATION_point.shp |head
#Shapefile Type: Point # of Shapes: 154
#File Bounds: ( -9.020, 37.370,0,0)
# to ( 28.780, 68.900,0,0)
#shpdump WPEU3M_polyline.shp |head
#Shapefile Type: Arc # of Shapes: 6158
#File Bounds: ( -22.979, 36.279,0,0)
# to ( 66.209, 72.031,0,0)
#shpdump EEA_region_Clip.shp |head
#Shapefile Type: Polygon # of Shapes: 376
#File Bounds: ( -10.475, 36.065,0,0)
# to ( 29.804, 69.753,0,0)
#shpdump NONEEA_region_Clip.shp |head
#Shapefile Type: Polygon # of Shapes: 9
#File Bounds: ( 0.157, 36.069,0,0)
# to ( 29.804, 42.110,0,0)
#shpdump WPEU3M_polyline_Clip.shp |head
#Shapefile Type: Arc # of Shapes: 4933
#File Bounds: ( -10.158, 36.279,0,0)
# to ( 29.804, 69.751,0,0)
#BOD5-broken
LAYER
NAME bod_idw
TYPE raster
STATUS off
OFFSITE 0 #palette entry no to be considered transparent
DATA bod_idw.tif
END # LAYER
#Phosphorous - works
LAYER
NAME phosphorus_idw
TYPE raster
STATUS off
DATA Phosphorus_idw.tif
END # LAYER
#Nitrate image - works
LAYER
NAME nitrate_idw
TYPE raster
STATUS off
DATA nitrate_idw.tif
END # LAYER
#PH image - works
LAYER
NAME ph_idw
TYPE raster
STATUS on
DATA PH_IDW8bit2.tif
END # LAYER
#shpdump SEA_rectangle.shp |head
#Shapefile Type: Polygon # of Shapes: 1
LAYER
NAME Sea
TYPE Polygon
STATUS off
DATA SEA_rectangle
#MAXSCALE 5000
CLASS
Name 'Sea'
COLOR 172 202 238
OUTLINECOLOR -1 -1 -1
END # CLASS
END # LAYER
# This is to make a double layer for the country boundaries
LAYER
NAME EEARegions
TYPE Polygon
STATUS on
DATA EEA_region_Clip
#MINSCALE 5000
#MAXSCALE 75000
CLASS
Name 'EEA Region'
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
SIZE 5
SYMBOL 0
END # CLASS
END # LAYER
LAYER
NAME NONEEARegion
TYPE Polygon
STATUS on
DATA NONEEA_region_Clip
CLASS
Name 'Non EEA Region'
#COLOR 255 0 0
OUTLINECOLOR 216 0 0
#SYMBOL 'dashed-line'
SIZE 4
END # CLASS
END # LAYER
LAYER
NAME Rivers
TYPE Line
STATUS on
#MINSCALE 1000000
DATA WPEU3M_polyline_Clip
HEADER 'rivers_header.html'
METADATA
"DESCRIPTION" "Rivers"
"RESULT_FIELDS" "WPCDCN1 WPCDCN2"
END
#LABELITEM 'WPCDCN1'
CLASS
Name 'Rivers'
COLOR 0 0 255
OUTLINECOLOR 0 0 0
TEMPLATE "river_query_query.html"
# LABEL
# ANGLE AUTO
# SIZE 8
# MINSIZE 8
# MAXSIZE 16
# COLOR 0 0 0
# #WRAP ' ' #character to wrap lines with
# #OUTLINECOLOR 255 0 0 #for 'glow' labels
# TYPE TRUETYPE
# FONT arial
# ANTIALIAS
# BUFFER 4
# END
END # CLASS
END # LAYER
#shpdump Europe_Towns.shp |head
#Shapefile Type: Point # of Shapes: 21731
#File Bounds: ( -9.700, 35.010,0,0)
# to ( 30.930, 68.650,0,0)
#NAME TOWN_CLASS POPN_BAND_ COUNTRY 1ST_ORDER_ 2ND_ORDER_ EASTING NORTHING POPN_000S popbnd
LAYER
NAME Towns
TYPE POINT
#MAXSCALE 10000
STATUS on
DATA Europe_Towns
TEMPLATE 'towns_header.html'
POSTLABELCACHE true #render this layer after all others
#LABELCACHE on
METADATA
"DESCRIPTION" "Population Centers"
"RESULT_FIELDS" "NAME COUNTRY POPN_000S"
END
CLASSITEM 'TOWN_CLASS'
CLASS
NAME 'NationalCapital'
EXPRESSION 'NATIONAL CAPITAL 1 MILLION TO 2 MILL'
SYMBOL 2
SIZE 9
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL 2 MILLION TO 3 MILL'
SIZE 9
SYMBOL 2
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL 3 MILLION TO 4 MILL'
SIZE 9
SYMBOL 2
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL OVER 5 MILLION'
#TEXT '*'
SIZE 10
SYMBOL 2
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL 500,000 TO 1 MILLIO'
SIZE 8
SYMBOL 2
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL 250,000 TO 500,000'
SIZE 7
SYMBOL 2
COLOR 255 0 0
END # CLASS
CLASS
EXPRESSION 'NATIONAL CAPITAL 50,000 TO 100,000'
SIZE 6
SYMBOL 2
COLOR 255 0 0
END # CLASS
END # LAYER
# This is a layer for smaller towns
LAYER
NAME Towns
TYPE POINT
#MAXSCALE 10000
STATUS on
DATA Europe_Towns
CLASS
EXPRESSION ('[popbnd]' gt 200000)
NAME 'OTHER'
SIZE 2
SYMBOL 3
COLOR 255 0 0
END # CLASS
END # LAYER
# THIS IS AN ANNOTATION LAYER FOR TOWNS
LAYER
NAME TownLabels
TYPE ANNOTATION
#MAXSCALE 10000
STATUS on
DATA Europe_Towns
#LABELCACHE on
LABELITEM 'NAME'
CLASS
LABEL
SIZE 13
FONT arialbold
TYPE TRUETYPE
POSITION uc
COLOR 0 0 0
OUTLINECOLOR 255 255 255 #for 'glow' labels
ANTIALIAS
BUFFER 4
END
END # CLASS
CLASS
LABEL
SIZE 12
FONT arialbold
TYPE TRUETYPE
POSITION uc
COLOR 0 0 0
ANTIALIAS
BUFFER 4
END
END # CLASS
CLASS
LABEL
SIZE 11
FONT arialbold
TYPE TRUETYPE
COLOR 0 0 0
POSITION uc
ANTIALIAS
BUFFER 2
END
END # CLASS
CLASS
LABEL
SIZE 10
FONT arialbold
TYPE TRUETYPE
POSITION uc
COLOR 0 0 0
ANTIALIAS
BUFFER 2
END
END # CLASS
CLASS
LABEL
SIZE 10
FONT arialbold
TYPE TRUETYPE
POSITION uc
COLOR 255 0 0
ANTIALIAS
BUFFER 2
END
END # CLASS
CLASS
LABEL
SIZE 7
FONT arialbold
TYPE TRUETYPE
COLOR 0 0 0
POSITION uc
ANTIALIAS
BUFFER 2
END
END # CLASS
CLASS
LABEL
SIZE 6
FONT arialbold
TYPE TRUETYPE
COLOR 255 0 0
POSITION uc
ANTIALIAS
BUFFER 2
END
END # CLASS
END # LAYER
# Fields in dbf:
# CO STNR QUALIFIER LOCATION R_NAME EEASTNR LAT LONG OLD_ID FLOW PH CONDUCTIVI
# CHLORIDES DO BOD5 COD AMMONIUM NITRATE PHOSPHORUS IAMMONIUM INITRATE IPHOSPHORU
LAYER
NAME Stations
TYPE POINT
#MAXSCALE 10000
STATUS on
DATA STATION_point
TEMPLATE 'stations_header.html'
HEADER 'stations_header.html'
METADATA
"DESCRIPTION" "Sampling Stations"
"RESULT_FIELDS" "STNR R_NAME FLOW"
END
#QUERY
#TEMPLATE os labels_query.html
#END # QUERY
#CLASSITEM 'LOCATION'
CLASS
Name 'Stations'
TEXT 'x'
COLOR 153 153 153
LABEL
SIZE 8
MINSIZE 6
MAXSIZE 16
FONT tomahabold
COLOR 0 0 0
TYPE TRUETYPE
ANTIALIAS
END
END # CLASS
END # LAYER
END # MAPFILE
