[mapserver-users] getSymbol(): (BUFFER):395 error
Daniel Morissette
morissette at dmsolutions.ca
Wed Dec 19 09:40:40 EST 2001
Tim Sutton wrote:
> Hi
> I have just upgraded my cvs to get up to date with 3.5 stable. My last
> build was made about 1.5 months back. I am using phpmapscript with php
> as a CGI. When I use the version built from todays cvs update, I get
> an error reading my map file:
> Warning: MapServer Error in getSymbol(): (BUFFER):(395)
The line that comes before line 395 in your mapfile contains the
"ANTIALIAS" keyword whose syntax has changed a few weeks ago. Now the
ANTIALIAS takes a boolean parameter, so the following should work:
ANTIALIAS TRUE
BUFFER 4
Note that the same change also happened with keyword "FILLED" in symbol
files.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
